Go Back   Jemsite > Guitars and Gear > JEM and Universe Guitars
Old 11-14-2001, 08:28 PM
UVmanMike UVmanMike is offline
Posts: 127  -  iTrader: (0)
Original Edge on Universe... - Good or bad thing??
I am curious about the playability differences on a UV with an original Edge bridge. I have played Lo-Pros all of my life, and have no experience with one on a 7 string. Are the older 90's UVs prized for their Edge 7s, or did Ibanez make a good choice making the Lo-Pro mandatory?? Thanks!!
Old 11-14-2001, 08:35 PM
Jay Satriani Jay Satriani is offline
Posts: 445  -  iTrader: (0)
I have wondered the same about the 6-Edge vs 6-Lo-pro Edge, what i have come up with is that they are very much alike, and that the biggest difference is that the lo-pro is more comfortable for resting your hand on the tremmolo, not accidently touching the fine-tuners... Otherwise it has been said that they are likewise in performance and tuning stability. Or, am i wrong ??
(Edited by Jay Satriani at 12:15 pm on Nov. 15, 2001)
Old 11-15-2001, 07:46 AM
SalemB SalemB is offline
Posts: 848  -  iTrader: (0)
I don't have any experience with 7's, but on a 6 string I found that it doesn't matter at all. It feels the same and it's got the exact same stability.
Old 11-15-2001, 12:07 PM
7 Dying Trees 7 Dying Trees is offline
Posts: 1,672  -  iTrader: (4)
I am not sure, but I do have an older lopro7 which has a starnge screw attachment mechanism for the trem bar, pretty rugged, but haven't tried it out, as the guitar is body-less at the moment. Does anyone know about these?
Old 02-10-2002, 06:12 PM
Sevenstringer Sevenstringer is offline
Posts: 263  -  iTrader: (3)
I prefer the LoPro on 6's or 7's. more comfortable in my opinion and string changes are easier. No need to dump the trem to loosen the 3mm screw to remove the string
Old 02-10-2002, 06:37 PM
Two hands31 Two hands31 is offline
Posts: 4,989  -  iTrader: (0)
The one with the screw in bar is probably a LO-TRS-7. *
Old 02-10-2002, 08:07 PM
trouble311 trouble311 is offline
Posts: 613  -  iTrader: (3)
I prefer the Lo-Pro....string changes are easier, it doesn't stick into my palm, and since I only have a Lo Pro intonation adjustment tool, intonation is easier and cheaper to set on a Lo Pro! *
Old 02-10-2002, 08:22 PM
Andy J Dampier Andy J Dampier is offline
Location: Ft Lauderdale-Fl....oh man...women...women...women...
Posts: 146  -  iTrader: (0)
I actually strongly prefer Edge trems. They flutter a lot more, (not that I really do any of that anyways...but...)...it just feels better to me. The tension On the Edge's seem more fluid to me than the Lo-Pro's. If and when I ever get a UV, I plan on doing a wide search for the original Edge 7's.
Old 02-10-2002, 10:59 PM
Can you buy an aftermarket Edge 7 from Ibanez or Floyd Rose???
Old 02-11-2002, 02:59 AM
bob oakman bob oakman is offline
Posts: 922  -  iTrader: (0)
Andy J Dampier on 6:22 pm on Feb. 10, 2002
Agreed... Though they may be a little more uncomfortable, they seem better at the job of tremulating. (hey! I made a new word) I don't know the reason for this... It's just an observation.
Old 02-11-2002, 03:31 AM
Rich Rich is offline
Posts: 16,463  -  iTrader: (19)
IME the Edge flutters *better* because the flutter sounds better. (ice cream) An Edge flutters a little slower or longer wavelength because the weight is heavily dispersed at the tail. Just like a metronome, move the weight toward the tip and it slows the frequency down. Slower flutter just sounds better to me, more audible/distinguishable/soulful (if flutter can possibly be soulful) than fast flutter, if you follow. And because the weight is further out, it's harder to stop because it has slightly more momentum. Put a 10 pound weight on a 1' rope and swing it, then swing it on a 3 ' rope, it will swing longer on the longer rope, the pendulum theory. Add to that the Edge weighs in several ounces heavier than a Lo Pro just adds to the pendulum. Just my opinion anyway, fill it with regular please. :biggrin:
Old 02-11-2002, 07:39 AM
jono jono is offline
Posts: 3,370  -  iTrader: (2)
Yep I agree entirely with Rich here
I like both equally and find they have different uses in different styles. For chord work or heavy riffing or jazz lines I genereally prefer the Lo-Pro but for more "acrobatic" playing I'd take a regular edge. And I agree with Andy about the string tension on a regular edge seems to lend the strings a more "fluid" feeling
  #13
Old 02-11-2002, 08:32 AM
nuno nuno is offline
Posts: 4,342  -  iTrader: (0)
agree with Jono: the Edge is more acrobatic than Lo-Pro, IMO
anyway i love'em both like sons, but since i'm an '80s nostalgic, i got a thing for the Edge.
nuno, the '80s nostalgic
[size=0.5]Jay, where were you all this time?[/size]
  #14
Old 02-11-2002, 12:33 PM
I should also add that the Edge doesn't bother me comfort wise one-bit, as I don't palm on the bridge. My pick is actually directly above the lower coil of my neck pick-up, and my palm rest on the bridge pick-up, right on the edge of the bridge. I can keep the strings a lot quieter this way, as well as get a slightly warmer sound from where I'm picking....and my bridge finish doesn't get worn down. So as far as comfort and the Edge goes, it doesn't really apply to me.
  #15
Old 02-12-2002, 11:10 AM
Entropy Entropy is offline
Posts: 228  -  iTrader: (1)
One thing I've always been interested in trying is putting a D-Tuna on an Edge-7 B-string.
Go from B to A.
I've got a D-tuna on my 777DY Edge bridge and it works great! *Sits right in the claw when at E and comes out parallel to the body while in D. *I've blocked the trem for dive-bombs only....ala Eddie.
Better yet....put 2 D-Tuna's on the B and E string.....go to a drop-A, drop-D arrangement for a ADADGBE tuning.
Gotta give props to the original Edge!
Guy
GHS GB8 1/2 Boomers Ultra Light+ Electric Guitar Strings
As low as $4
at 5 sellers
Fender 7150M Original Bass Medium Strings
As low as $15
at 6 sellers
Members with more than 50 posts don't see this bar
Ernie Ball 2240 Regular Slinky RPS 10 Electric Guitar Strings
As low as $2
at 3 sellers
zZounds
As low as $0
at sellers
Martin MSP1100 Marquis 80/20 Bronze Light Acoustic Guitar Strings
As low as $5
at 7 sellers
Fender 5250XL Short Scale Bass Extra Light Strings
As low as $19
at 3 sellers
Rocktron Utopia Expression Guitar Effects Pedal Silver
As low as $79
at 3 sellers
Ibanez ART400H Electric Guitar Amber
As low as $500
at 6 sellers
Tech 21 Trademark 60 Combo Amp
As low as $609
at 3 sellers
Alfred Santana Classic Santana Guitar Tab Songbook
As low as $18
at 10 sellers
Gibson SJ-200 Standard Acoustic-Electric Guitar Vintage Sunburst
As low as $3799
at 5 sellers
Martin MSP4600 Phosphor Bronze Extra Light 12-String Acoustic Guitar Strings
As low as $10
at 5 sellers
Fishman Prefix Pro Preamp and Pickup System In Narrow-Format
As low as $290
at 4 sellers
Line 6 ToneCore Uber Metal Distortion Pedal
As low as $99
at 17 sellers
edge bridge, edge trem, edge trems, floyd rose, pro edge, steve vai, string tension, trem studs
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
