Old 04-20-2009, 06:32 PM
RNRCRAZYKNIGHT  is offline
Posts: 84  -  iTrader: (0)
Pickguard question...
I'm in the process of building a JEM2K-DNA. The body is coming from Herc Fede within the next couple of weeks. What is the correct pickguard I need to get for this guitar? Where can I purchase it from?
THANX!!!!!
Scott
PS I will post pics as soon as I have some.
Old 04-20-2009, 06:39 PM
Zgicc  is offline
Posts: 133  -  iTrader: (0)
Re: Pickguard question...
Its a transparent plastic pickguard no?
Try one of the links/sponsors above. They might have the one you'd like.
Old 04-20-2009, 06:47 PM
Rich  is offline
Posts: 19,348  -  iTrader: (21)
The correct glow guard is discontinued.
Old 04-20-2009, 08:16 PM
What is this "glow guard"? They look clear in the pictures I've seen. Do they glow in the dark or something?
THANX!!!!!
Scott
Old 04-20-2009, 08:44 PM
Rich  is offline
The guards give off a blue glow in sunlight, and light up like a 100w light bulb under black light.
Old 04-21-2009, 03:46 AM
WMerkert  is offline
Posts: 1,115  -  iTrader: (1)
Images: 5
Here you can see the blue glowing a little bit (much more under sunlight):
And here under black light:
Old 04-21-2009, 04:10 AM
Does this look like the material it's made with? Or is it to "blue"?
Old 04-21-2009, 04:42 AM
WMerkert  is offline
Images: 5
I would say it's too blue.
Old 04-21-2009, 06:01 AM
Zgicc  is offline
Those are coloured however.
I'm not sure but:
There's a chance that the chemical in the pickguards giving the glow was Strontium Aluminate.
CAS Number 12004-37-4
This is mixed into the plastic and then molded into a pickguard or anything really. Maybe some pickguard makers can try out this idea?
From Wikipedia: "Strontium aluminate is vastly superior phosphor than its predecessor, copper-activated zinc sulfide; it is about 10 times brighter, 10 times longer glowing, and 10 times more expensive than ZnS:Cu. It is frequently used in glow in the dark toys, where it displaces the cheaper but less efficient ZnS:Cu. However, the material has high hardness, causing abrasion to the machinery handling it; coating the particles with a suitable lubricant is usually used when strontium aluminate is added to plastics."
Warning: Using the CAS Number try to find MSDS (A chemical data sheet) before handling. Might be hazardous - However its used in child's plastic toys so it is unlikely. Safety first.
Or easier method to get some glow in the dark powder which can be easily found on the web.
Old 04-21-2009, 07:28 AM
How about this?
Old 04-21-2009, 07:30 AM
Zgicc  is offline
Does it glow in the dark?
Old 04-21-2009, 07:51 AM
WMerkert  is offline
Images: 5
No it doesn't.
Old 04-21-2009, 08:34 AM
WMerkert  is offline
Images: 5
Originally Posted by RNRCRAZYKNIGHT View Post
How about this?
Better i think.
Old 04-21-2009, 09:46 AM
The last picture I sent is of 1/8" thick fluorescent blue acrylic plexiglass. So I would imagine this glows under black lights. I emailed to get more info and some pics.
Scott
dna, jem, pickguard
pickguard question shrly1 Tech: Setup, Repairs and Mods 2 05-29-2008 10:13 AM
Pickguard question... RGR570 Other Ibanez Guitars (including Premiums) 10 08-18-2006 04:46 PM
Jem Pickguard Question bluealien JEM and Universe Guitars 3 02-07-2006 12:21 PM
DNA Pickguard Question jay ratkowski JEM and Universe Guitars 18 10-04-2001 02:48 PM
