Old 01-07-2001, 01:33 PM
ripl3y  is offline
Posts: 747  -  iTrader: (0)
Pointers on buying a 2nd Hand Jem7VWH - What to look out for
Hi chaps,
I've found a VWH for £795 which I'm going to have a look at on Tuesday night.
The seller says it's in good condition, with just a couple of small chips around the MG and Jack area.
It also needs a new bridge pickup.
Asides from what I normally look at when buying a new guitar, are there any particular areas I should look more closely at with the VWH, or any common problems that occur?
Thanks
Steve
Old 01-07-2001, 01:53 PM
Paul 143  is offline
Posts: 11  -  iTrader: (0)
£795 is a good price. I bought a 2nd user Jem7VWH which was in excellent condition, but frets 22 &amp; 23 had both lifted from the ebony. There was about a 1 mm gap under each fret @ the high E side. The guitar was a 1999 issue.
Old 01-07-2001, 04:13 PM
ripl3y  is offline
Cheers,
I'll make sure I look out for that one.
I was a little concerned about his bridge pickup going kapputt on him, it made me wonder what he'd been doing with it , and he's swapped the neck pup into the bridge position, so that's a little more work for me to do, but as long as the guitar is sound then I'll be grabbin' it.
Steve
Old 01-08-2001, 07:55 AM
larsmars  is offline
Posts: 29  -  iTrader: (0)
I've got mine for £620 and it was in mint condition and with a case.
It seems to me strange that bridge pick-up is damaged.
Lars
Old 01-08-2001, 12:19 PM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
Correct me if I'm wrong, but the neck pickup won't work right in the bridge position because of the 'F-Spacing" in the bridge pickup. *The strings won't be aligned propery with the magnets.
Wish I could help more, but I have no idea how much *795 Lbs. is (i don't even know where the key is!)
Somebody is selling 2 Evo pickups on ebay
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1402482114 on the neck and
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1402482095 for the bridge.
They don't close 'til next week, so if you buy the guitar, keep that in mind....
~Kenny
Old 01-08-2001, 12:30 PM
jemsite  is online
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
JEMs have F-spaced neck and bridge pickups. To be honest you could use the standard ones without any real sonic difference.
In regard to the VWH, I would inspect it like any other used guitar if possible. See the jemsite-->Guitar area for tips. Good luck... glen
Old 01-08-2001, 12:47 PM
Scott Smith  is offline
Posts: 436  -  iTrader: (7)
Those 2 auctions are for black Evo's. I personally like the white ones with gold polepieces for the VWH. But that's individual taste. Actually black ones may look pretty cool. The non F-Spaced factor won't be a big problem. I had a S540 with a non F-Spaced PU, couldn't tell the difference...
Is it me or is a 65 dollar buy price a bit steep for a used DiMarzio? I think when I ordered a set about 2 years ago they cost around 100 for both...
Old 01-08-2001, 06:18 PM
ShredHead42  is offline
Posts: 344  -  iTrader: (0)
i put an SD Full Shred Humbucker in the bridge of my jackson, before learning abt TremBuckers... oops! *but it sounds good... i cant really tell a difference... they don't get louder when i bend the strings or anything. *
but i still cant believe i didn't know that. *=X
bridge pickup, bridge pickups, bridge position, evo pickups, neck pickup, neck pup
