in 2 days i have the chance to put a jem7v neck on an rg450gx body.
this is the guitar i am putting the neck on. ignore the fact it says rg390 as it is actually an rg450gx
http://spaces.msn.com/fastfinger89/photos/?_c02_owner=1
i have changed the pickups to evos and that has been the only change i have made.
this is what the orginal guitar looked like. if you go to rg series and then go to rg 450gx you can see it there.
http://www.ibanez.com/parts/2004_PAR...ndex_spec.html
the neck on this guitar at the moment is a wizard 2, exactly the same as the neck on an rg350dx. i have looked at the neck measurements on ibanez.com between the ibanez rg350dx and the ibanez jem7v and the only difference is the radius which is
jem
Scale 648mm/25.5"
a : Width at Nut 43mm
b : Width at Last Fret 56mm
c: Thickness at 1st 19mm
d : Thickness at 12th 21mm
Radius 430mmR
rg350dx
Scale 648mm/25.5"
Radius 400mmR
i think the radius doesnt matter because when the neck of the guitar hits the body it goes flat on the backside so it can fit into the body by sliding in. therefore he radius changes.
i measured the width of my rg neck on the last fret and it is 56mm just like a jem. so as far as i know the
jem neck will fit without any problems.
can someone please varify whether this will work for me or not.
will it fit or not?
will it ruin my guitar, tonewise and playability wise.
ps- if the jem neck wont fit, will a j-custom rg neck with the vine inlay fit?
so i have two options
1. jem7v neck
2. rg prestige neck with vine inlay.
all im trying to do is put a
ibanez neck with a vine inlay on that will fit. so if you know any other necks that will fit or any problems that i will encounter please let me know.
ps- dont ask about how im gettin these necks because is a long story.
cheers
tobi atkins
