Old 03-22-2007, 12:54 PM
j45m16  is offline
Posts: 31  -  iTrader: (0)
Smile
question about neck
just bought a jem 7dbk and when i pull back on the neck the strings go dead against the frets also has som fret buzz on the bass side any help would be appreciated j
Old 03-22-2007, 01:23 PM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
Re: question about neck
adjust the truss rod you may have some back bow
Old 03-22-2007, 05:12 PM
ibanezman08  is offline
Posts: 40  -  iTrader: (0)
when you pull back on the neck? don't you mean on the whammy bar? if that's the case, yeah maybe you do have a backbow (stupid biflex truss rods...haha) but it's hard to say without actually looking at your guitar.
if may also be that your action is way too low.
Old 03-22-2007, 06:37 PM
Ranz 777  is offline
Posts: 686  -  iTrader: (0)
Images: 16
Dont pull back on your neck!
Old 03-22-2007, 09:44 PM
j45m16  is offline
no I do not mean tremelo. Ina seated position if Iput tension on the body and neck at the same time it chokes the strings .Not heavy abusive pressure .
Old 03-22-2007, 10:58 PM
i don't get it.
Old 03-23-2007, 03:29 AM
nightfiend14  is offline
Posts: 1,005  -  iTrader: (10)
first why in the world would you do that? it's going to happen on pretty much any guitar, wood bends so naturally if you put both in tension that way it's going to pull the strings closer to the neck. So either the action is fairly low so when you pull the strings touch the frets or you are just pulling way to much which you shouldn't really do to start with. This isn't the 50's man, there is no need to do neck bends like way anymore.
Old 03-23-2007, 09:52 AM
jim777  is offline
Take it in for a setup if you can't do a good one yourself. I think some of us thought you were going 'Billy Sheehan' on it
Old 04-28-2007, 12:05 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
That neck is very flexable as it is so thin. I think it might be the thinnest Ibanez ever made. They play incredibly well, but you sure can bend the thing. The truss rod should be adjusted so there is a very slight bow (aka "relief"). If you fret the low E string at fret 1 and fret 20, there should be a little space between the string and the middle frets.
Old 05-02-2007, 12:18 PM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
that's a great way to get NJ cracks. any guitar you play will do that and even more so will the DBK due to the super-thin neck.
DON"T PULL BACK on the headstock problem solved.
Old 06-11-2007, 05:10 PM
I agree that the 7DBK neck is the most flexible neck Ibanez has ever made. But it sure does play nice!!! I guess they aren't for the "animal" type players. Maybe you should slap on a Wizard II neck which is a lot stiffer and beefier. Then put the old neck back on if you ever decide to sell the guitar?
billy sheehan, fret buzz, truss rod, truss rods
Jem7PBK - Question about the neck Martijn JEM and Universe Guitars 3 01-03-2007 09:04 AM
Wizard II Neck Nut Replacement Question Dark Alone Tech: Setup, Repairs and Mods 10 09-13-2006 10:22 AM
Painted neck? Sanded neck? Drache713 Other 7-string Guitars 28 12-25-2005 12:45 AM
Neck profiles question from an Ibanez newbie Anonymous Other Ibanez Guitars (including Premiums) 3 05-06-2004 09:26 AM
Different Jem's = Different Neck profiles? - a question rega jem7vwh JEM and Universe Guitars 13 01-31-2001 04:14 PM
