Originally Posted by -Rhaab
If your routing on a completly blank piece of wood you can use the plastic piece as a guide, you just have to make a reverse template, basically you just take the plastic piece and trace it on a piece of scrap wood like thin plywood. then use the bits to cut it out. if its on an allready existing body you have to route a different area so it doesn't get in the way of the allready routed electronic cavity.
???? This will depend if its a front route under pickguard (JEM7VWH) or rear route like Floral Jems, even if its already routed you can still secure a template on the back and measure, you can use a doel to line some of the pots too.
When I routed my RG570, rear control, the new route for the Sustainer when from control cavity to the jack input cavity to get the board to be in the correct position.
