Old 11-23-2003, 12:21 AM
Ravager  is offline
Posts: 115  -  iTrader: (0)
Severe JEM problem...
Hey guys... um... my output jack isn't working.
At first I thought it was the cable, but I tried it in my Fender and it works. Is there a way maybe I can try to fix it myself? Or do I have to ship my baby away?
Old 11-23-2003, 02:15 AM
Petie  is offline
Posts: 2,877  -  iTrader: (0)
Stuff like that is very easily fixed, just pop open the cover on the back and look for the loose wire! Unless it's the wire from your volume control, in which case you'll have to take the strings off, remove the pickguard and ... look for the loose wire!
Old 11-23-2003, 02:26 AM
Ravager  is offline
I don't see any loose wires. I think the problem lies in the cavity inside the output jack.
Old 11-23-2003, 03:30 AM
Ravager  is offline
Never mind.
A set of wires is ripped from the metal part under the jack panel. I have to solder them back on.
Any tips or things I should worry about when doing this?
Old 11-23-2003, 05:01 AM
Petie  is offline
If you're not comfortable with a soldering iron find someone who is, but it's really not difficult work, I've been tinkering with the guts of guitars and pedals since I was 15. Just remember not to touch any part of the guitar body with the iron.
Old 11-23-2003, 02:20 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
If you get really stuck you have the benefit of LGM Guitars being only an hour and a half away
Old 11-23-2003, 02:21 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Or his hands. IVe still got a nasty scar on my leg where I dropped it. It didnt hurt at first and the skin just turned solid white *immediatley* and about ten minutes the nerves just stood up and went *OWWWWWWWWWWWWWWWWWWWWWWWWWW*
Old 11-23-2003, 02:44 PM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
Originally Posted by Ravager
Never mind.
I have a fantastic tip ... Take it to Jeremy,Honestly,Seriously ... If i lived that close i doubt very much i'd even touch my guitars
Rob
Old 11-23-2003, 06:49 PM
bpd111  is offline
Posts: 1,628  -  iTrader: (7)
If I lived that close, I probably wouldn't even play them!
Old 11-26-2003, 02:11 AM
wilch  is offline
Posts: 1,783  -  iTrader: (0)
Images: 1
That's sooo close! Yeah, take it to him!! take it to him!! Even if I didn't have a problem with a guitar, I'd still take it to him if I were that close.
There'd be a bit of, "ok, i want this done, then this, and this...Oh, and this too cause its cool, and that as well...and..and..."
wil..
Old 11-28-2003, 04:58 PM
hamand  is offline
Posts: 453  -  iTrader: (0)
A single bit of advice: one end of the soldering iron is hot, the other isn't.
Old 11-29-2003, 04:22 AM
Petie  is offline
Yeah, you can figure out which end is hot by touching it to the tip of your tongue*
*Not real advice
guitar body, lgm guitars
