Old 06-14-2009, 01:44 AM
RNRCRAZYKNIGHT  is offline
Posts: 84  -  iTrader: (0)
Steve Vai pickup question...
I wanted to see if anyone knew which neck pickup is in Steve Vai's guitar that has the Sustainer in it?
THANX in advance.
Scott
Old 06-14-2009, 01:52 AM
Pursuit  is offline
Posts: 680  -  iTrader: (0)
Re: Steve Vai pickup question...
That guitar is FLO isn't it?
I would think it's a DiMarzio Evolution pickup like all the other JEM7VWH's, unless I'm missing something big and the sustainer is part of the pickup!
Old 06-14-2009, 01:57 AM
Timbaline  is offline
Posts: 508  -  iTrader: (0)
Reviews: 7
Flo has the sustainer. The sustainer is the pickup. http://www.fernandesguitars.com/susproducts.html
Old 06-14-2009, 02:27 AM
Dummy me realized that after I started doing a little digging. I guess I should do a little homework before I ask. I'm used to the Sustainiac.
How does the Fernandes Sustainer sound as a pickup? There is not a Fernandes dealer where I live.
Scott
Old 06-14-2009, 03:27 AM
Reviews: 7
Scott
....... I have never played a guitar with a fernandes sustainer, but you can find songs where Vai, uses it such as whispering a prayer.
Old 06-14-2009, 07:38 AM
littlephil  is offline
Posts: 422  -  iTrader: (0)
The sustainer isnt a pickup. It only sustains. If you have one you cant have a neck pickup.
Old 06-14-2009, 12:25 PM
drizzt75  is offline
Posts: 129  -  iTrader: (0)
the sustainer is a pickup and works like a normal neck pickup when the sustainer is switched off vai uses the single coil version and has a dummy pickup next to it to fill the humbucker spacing but i assure you the sustainer itself acts like a normal pickup when the toggle is set to neck position and the sustainer is inactive
Old 06-15-2009, 04:43 AM
Only the humbucker sized sustainer is a pickup. The single coil driver is not a pickup, but if you put it in a humbucker cavity you can put a single coil sized pickup in next to it.
Old 06-15-2009, 05:04 AM
Pursuit  is offline
Uh oh... here we go again...
steve vai pickup
steve vai style question newbieguitarmaker Guitar Lessons & Music Theory 13 02-12-2006 02:01 PM
FS: Dimarzio steve vai pickup/ black. Kubiac3 Classified Ads: Guitars and Gear 2 08-25-2005 08:41 PM
What is Steve favorite pickup - EVO or PAF dimitar Pickups & wiring 9 07-28-2005 11:48 AM
Dimarzio Steve Morse signature pickup urkoman Gear and Equipment 4 05-01-2002 01:35 PM
RG3120 with Steve Special pickup ibzRG3120 J-Custom, USA Custom & Prestige Ibanez Guitars 2 06-06-2001 09:07 AM
