Old 04-05-2005, 06:54 PM
heeby1  is offline
Posts: 6  -  iTrader: (0)
String stretching messed with my tremolo :(
Hey, wonder if anyone can help me with this-
I was stretching a new set of strings when i noticed that, whilst stretching, the string block had moved forward, presumably messing up the intonation.
I tried the next string up (G) and again, the block moved forward again from the stretching pressure.
Is this normal? How do i prevent it from happening in the future?
Any help would be much appreciated (Have included a pic with the saddles that moved in the red circle- this was taken before it happened)
Thanks
Old 04-05-2005, 06:57 PM
Rich  is offline
Re: String stretching messed with my tremolo :(
Uhhhh, tighten the screw?
Old 04-05-2005, 06:59 PM
giannifive  is offline
Posts: 484  -  iTrader: (8)
I'm confused. Was it just the saddles that moved? Or did something else shift?
If it was just the saddles, all you have to do is readjust your intonation, and after you do so make sure the saddle screws are tight this time! (But be careful not to strip them.)
Old 04-05-2005, 10:32 PM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
... and lighten up on your string-stretching regimen. You shouldn't have to pull them THAT hard! (Either that, or your saddle lock-down bolts were really loose.)
Old 04-05-2005, 10:38 PM
Rich  is offline
I stretch that hard, and move saddles all the time, but I stretch before I measure bridge radius and intonate [which is when I tighten the lock down screws] so no biggie
Yet another poorly mixed song by your truly IbanezroadstarII Multimedia: Music, Pictures & Sounds 33 03-16-2006 10:01 PM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha Triangle Guitar Lessons & Music Theory 3 05-31-2005 08:57 AM
Excessive stretching of High-E string on lo-pro BluewookieJim Tech: Setup, Repairs and Mods 8 02-23-2003 10:00 AM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 01:20 AM
