SWIRLING A GUITAR
Page 1 of 6
07-05-2009, 07:14 AM
ANT5150
Posts: 163 - iTrader: (
SWIRLING A GUITAR
I have had some good results from using acrylic car paints and a bucket of water but have read in many forums that I can use Humbrol enamel paint (modeling paints). Is this true?
I have tried enamel paint and all it seems to do is clump together. Will Borax help this situation or should I stay with the car paints.
Also does temperature affect the swirl process as I have noticed that water straight from the tap seems to stop the paint from swirling.
Please help.
ANT5150
Find all posts by ANT5150
07-05-2009, 08:22 AM
Brosa
Posts: 1,660 - iTrader: (
Re: SWIRLING A GUITAR
Succesfull swirlers don't give their secrets away (it's their business, just like the coca cola ingredients). The only way to find out which paint to use or which paint works the best, is trial and error.
Good luck.
Sam.
Brosa
Find all posts by Brosa
07-05-2009, 11:53 AM
Ibateur
Posts: 2,947 - iTrader: (
... and, if you've had success with auto paints, I would stick with those and perfect them.
But, yes, I understand that Borax will prevent the clumping.
Ibateur
Find all posts by Ibateur
07-05-2009, 11:57 AM
Takin' a Ride
Posts: 1,759 - iTrader: (
My suggestion would be to prepare some sanded, white-painted boards and experiment with a bunch of different methods until you get the result you want. I would suggest speaking to a paint distributor or a hot rod shop. I don't know anything about swirling, but my feeling would be that some type of automotive paint would work best. The reason I say that is that many automotive paints self-level very well and therefore could give you a better end result. I'd probably avoid most hobby paints because the build would be very high and they probably wouldn't level very well. These paints are intended to be used with a brush, which is why you're having a problem. Some type of thinner would be your best bet if you wanted to keep using those.
Takin' a Ride
Find all posts by Takin' a Ride
07-05-2009, 01:11 PM
ANT5150
All of your help is appreciated. Thank you.
ANT5150
07-05-2009, 02:56 PM
RNRCRAZYKNIGHT
Posts: 84 - iTrader: (
Check this out
http://www.youtube.com/watch?v=8XUEbXAm-hY
Scott
RNRCRAZYKNIGHT
Find all posts by RNRCRAZYKNIGHT
07-06-2009, 03:02 PM
jonnyboy mills
Posts: 568 - iTrader: (
Everyone asks that youtube guy "do you use this?" "do you use that?", and he never posts a single reply.
Im doing a bit of research on swirling, i got some info off project guitar (google it). The paints seem pretty easy to obtain, It helps if you have some knowledge about painting, I used to work in a car body shop many years ago, but i have allways keept my hand in so to speak.
with regards to people not wanting to tell you how its done, i just think thats a very foolish attitude to have.
some one could give me the music to Rachmaninov's 3rd piano cocerto, all the notes there in black and white, but it does not mean i would be able to play it!
jonnyboy mills
Visit jonnyboy mills's homepage!
Find all posts by jonnyboy mills
07-06-2009, 04:06 PM
hangingmonkey
Posts: 116 - iTrader: (
Anyone know where i can buy borax from?
hangingmonkey
Find all posts by hangingmonkey
07-06-2009, 04:12 PM
Tubarão Guitars
Posts: 3,963 - iTrader: (
for my swirls i just use SAYERLACK auto paints, a brazilian brand.
Someone able to come to Brazil-São Paulo to buy those paints? Don't think so.
"Takin' a Ride" gave you everything you should and would know about swirling.
AND that swiling video isn't a good example of how to swirl IMVHO.
He swirled a green body to some shades of gray and everybody knows you need to start from white base coat to get bright colors.
Anyway, the result on that GMC was cool, 9 out of 10.
My $0,02
Tubarão Guitars
Visit Tubarão Guitars's homepage!
Find all posts by Tubarão Guitars
07-06-2009, 08:32 PM
kelmaur
Posts: 303 - iTrader: (
hangingmonkey
what is the clear liquid in the bucket he was pouring the paint into?
kelmaur
Find all posts by kelmaur
07-06-2009, 08:42 PM
Timbaline
Posts: 508 - iTrader: (
Reviews: 7
It is a rare substance and completely unnecessary for human life, I think it's called "water".
Lol
Timbaline
Find all posts by Timbaline
07-06-2009, 09:06 PM
dccomputersa
Posts: 404 - iTrader: (
Reviews: 4
Use automotive paint, and water. There is no real need for borax, but if you insist you can get it at Walmart or the grocery store. Use a white basecoat or primer.
dccomputersa
Visit dccomputersa's homepage!
Find all posts by dccomputersa
07-06-2009, 09:17 PM
nato101010
Posts: 1,002 - iTrader: (
Timbaline
Lol
I pissed my pants laughing when i saw that.
nato101010
Visit nato101010's homepage!
Find all posts by nato101010
07-06-2009, 11:59 PM
AxeHappy
Posts: 678 - iTrader: (
Google Marbling. Seriously.
Try drawing inks. Stuff like Speedball and whatnot.
If it doesn't float right out of the jar add a single drop of Kodak Photo-flo 200(per 5ml of ink) to the ink. Mix the hell out of it and put another drop of the (now mixed) ink on your size. If it still doesn't float then that colour won't float. Make a note and move on.
You will have to alum the surface of anything you want to marble with this method other than absorbent papers.
AxeHappy
Find all posts by AxeHappy
07-07-2009, 06:28 PM
courtney2018
Posts: 1,270 - iTrader: (
Reviews: 16
dccomputersa
I swirl as well. I don't know where the Borax came into being one of the ingredients for swirling, but I never found it to help. I've used it, if not used it, I can't tell a difference. It does give the water a slicker feel, but the paint is suspended on top of the water because it's lighter than water (because it's an oil based paint). The paint never mixes with it.
If you want to try it out on the cheap, try hobby paint. I've used Testor brand which is what you commonly find in the model car and planes section of the hobby store. I've used automotive paint too. The automotive paint gives you the biggest range of colors though.
courtney2018
Visit courtney2018's homepage!
Find all posts by courtney2018
Page 1 of 6
what age guitar
swirling is an art tutorial
how to swirl a guitar
what paint to use with swirling
Swirling a set neck guitar
Jemwielder
Tech: Setup, Repairs and Mods
10:10 PM
Tut for guitar swirling here
ddragon64
02-01-2005
12:51 PM
Swirling an RG?
Swirly
01:51 PM
How much would it cost to get? - Swirling a guitar.
Merlin88
Gear and Equipment
08:34 PM
Swirling A Guitar ??? Any Idea Besides This - I need some he
howiedaydmb
02:54 AM
12:41 PM
