Old 02-17-2006, 12:07 PM
StTan  is offline
Posts: 46  -  iTrader: (0)
Question
The difference in pull ups on a Edge Pro vs Edge
With aprox the same string height, fretting and doing a pull up, the Edge Pro lower the strings so much more than the Edge, making the fretted string touch the next fret. Is this a common thing or is it a set up thing?
Old 02-17-2006, 07:56 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: The difference in pull ups on a Edge Pro vs Edge
Sounds like set-up to me. Your Edge Pro is probably sitting lower in the body.
Old 02-18-2006, 01:41 PM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
I don't know about the Edge Pro, but on both my LoPros I can pull up to 5-6 semitones (12th fret G-string)
When set-up correctly the limiting factor is the tremarm holder hitting the body inside the cavity.
arm holder
Edge Pro, almost no pull back before string snaps doublecush Tech: Setup, Repairs and Mods 2 07-07-2005 01:17 PM
Old Edge versus New Edge thebigugly Other Ibanez Guitars (including Premiums) 7 01-23-2005 12:51 AM
Edge Pro II vs. Edge Pro JiMoSiTY Other Ibanez Guitars (including Premiums) 4 10-23-2004 07:01 PM
Replacing Lo-Pro Edge trems with original Edge? Max-T Tech: Setup, Repairs and Mods 1 09-06-2004 08:54 AM
lo pro edge - don't want to pull up chip james JEM and Universe Guitars 5 01-27-2001 05:14 PM
