Old 08-05-2006, 01:39 PM
stratosqueeg  is offline
Posts: 274  -  iTrader: (9)
Universe odd serial numbers....
Hey guys
I was curious.....
I was looking to maybe purchase a Universe and was looking at
Ibanezrules' website.
They have a universe UV7BK with a non UV plate, 256K number
and another one original uv plate with proper
serial.
http://www.ibanezrules.com/used.htm#JEM
I'm sort of wondering why and what is the reason for the 256 numbers
since I can't seem to find any info about those serials anywhere.
Does that make them more collectable or something?
I also wonder what the range is on these serials (256XXX up to 2??XXX)
Any insight would be most appreciated.
Squeegy the confused
Old 08-05-2006, 01:59 PM
King Nothing  is offline
Posts: 333  -  iTrader: (1)
Re: Universe odd serial numbers....
If your worrying they may be fake, don't worry man cuz Rich is one of the most trusted members on this site
This info is taken off Rich's site:
JEM - UV - JEM plates are 6 digit and the first 2 digits is the production year while the last 4 is the consecutive number JEM built from inception. 870060 is an 87' and the 60th JEM built. Except for the very first batch of 90' UV plates that began 00, UV plates are also dated by the first 2 numbers. 00 is a 90', 90 is a 90', 91 is a 91'. A Universe plate 912787 would denote a production year of 91 and the 2787th Universe built. Where things go astray is when the Jem line went to AANJ in 93'. This is where you start seeing consecutive numbered plates on the remaining regular joint models that no longer indicate year. 160225 was a very odd plate number I came across on a Jem. Most that I'm aware of are what I call 250k plates [25****] and current 2003' FP15th's have 260K plates [26****] meaning there have been over 10,000 Jem's made since they deviated from the serial plate numbering. No matter as most can be dated by the headstock serial # but there will be guitars without them and the plate number will be the only number available. Late BFP's with direct mount pickups for example which bear these 160k/250k plates and no headstock sticker. The UV plate numbers also changed to these consecutive plates and will be found on late UV7BK's in both green dot and silver. Universe plate 912787 would denote a production year of 91 and the 2787th Universe built.. Universe number 250435 could be a 96' UV7 green dot and the 435 indicates the 435th plate. Pinning these guitars down to closer than a 2 year window would be tough. This actually makes alot of sense from a manufacturing stance as they no longer had to order plates that denoted year of production and could just order consecutive numbered plates without care to year. They would no longer be restricted to using a specific plate in a specific year and any batch of plates would be good forever.
BLANK NECK PLATES
Guitars with the blank numbered cast plate will bear a headstock serial sticker denoting the Fujigen production of the parts
http://www.ibanezrules.com/catalogs/...nce/dating.htm
direct mount pickups, mount pickups, neck plate, neck plates
Korean serial numbers AMH82 Other Ibanez Guitars (including Premiums) 5 05-07-2006 04:26 AM
decoding universe serial numbers? wildkoba JEM and Universe Guitars 9 03-19-2002 11:12 PM
RG serial numbers '87-'02 woodshed Other Ibanez Guitars (including Premiums) 1 03-02-2002 01:25 PM
RG ART Numbering - Serial and Control Number Analysis Rich J-Custom, USA Custom & Prestige Ibanez Guitars 19 01-06-2002 11:17 PM
2 Serial numbers? Screamin JS (Satriani Model) Ibanez Guitars 4 03-21-2001 01:10 PM
