UV777PBK trem problem - Very stiff
04-23-2001, 07:44 AM
wyzenhymer
Posts: 82 - iTrader: (
I recently got this Universe and reset everything except filing the trem knife edges. It feels so stiff compared to my Jems. Is this normal? Could the beveled knife edges being baddly worn cause the trem to feel very stiff? I haven't been able to find suitable files in any hardware store locally, but if this is the problem, then I will look some more!
* G.M.
wyzenhymer
Visit wyzenhymer's homepage!
Find all posts by wyzenhymer
04-23-2001, 10:18 AM
jemsite
Administrator
Posts: 9,259 - iTrader: (
that is normal, since the UV has the extra low-B and hence
string tension
for the tremolo to counteract... glen
jemsite
Find all posts by jemsite
04-23-2001, 11:36 AM
kennydoe
Posts: 3,416 - iTrader: (
it could also be the age of the springs - newer spings are stiffer than ones that have been broken in. *if you changed the springs when "resetting everything" that'd definitely be a major conributing factor.
I changed the springs in my jem when i first got it and it was noticably stiffer - didn't take too long to break on (or maybe i just got used to it).
The Jemsite tech section has tips for accelerating *spring-break-in time, but if you play a lot you probably don't need to bother.
~kenny
kennydoe
Visit kennydoe's homepage!
Find all posts by kennydoe
04-23-2001, 12:04 PM
Posts: 19,344 - iTrader: (
New or old, springs become 'static' with lack of use. To free them up, hammer that whammy!!
04-23-2001, 12:18 PM
YaYoGakk
Posts: 691 - iTrader: (
This maybe a stupid question... but
when should you change springs or
is there any need to change them.
Thanx Alden
YaYoGakk
Visit YaYoGakk's homepage!
Find all posts by YaYoGakk
04-23-2001, 12:30 PM
jemsite
Administrator
This maybe a stupid question... but when should you change springs or *is there any need to change them
You might have to adjust the tremolo claw. If the new springs are stiffer you would loosen the
claw screws
Springs aside, the UV trem will ALWAYS be substantially stiffer than the JEMs... glen
jemsite
04-23-2001, 03:19 PM
kennydoe
I knew it because the guitar was 10 years old, 5 of them spent in the case and the guitar was in good condition, but not well maintained.
When I put my .010s on it, i had to screw the
trem claw
springs in just about all the way and the bar just didn't feel right. *
I put new springs in and loosened each claw screw no fewer than 3 full turns.
Glen is right - there's quite a bit of extra tension on the bridge of the UV from the big extra string. *
Changing springs is very cheap and very easy, not to mention reversible if you don't like the results. *Give it a shot if you have any doubt. *Just be prepared to adjust the bridge.
~Kenny
kennydoe
04-23-2001, 04:17 PM
YaYoGakk
I have a lo
pro edge
on my yamaha
and i notice that i don't have that flutter
i used to have... well i have none in fact.
and i love flutter so much
i changed the springs but still no help. The trem was installed about 6 years ago. What might the problem be? *this is the only lo pro on my guitars so i'm not that experienced with them so any help would be appreciated.
Thanx Alden
YaYoGakk
04-23-2001, 04:37 PM
kennydoe
It'll take a few days or weeks to get flutter back on new springs. *Don't give up if you don't have flutter on new springs on the first day. *Give 'em a little bit of time.
The flutter decreases as the
string guage
increases too - if you switched to a higher gauge, that could be the cause of your lost flutter. *I had 11s on my RG and it had little to no flutter.
Also, make sure the bar socket is tight - you may have to pop the bridge off to do this (you'd have to pop it to do the springs anyway). *The nut underneath came loose on my RG and that made the flutter disappear too. *The threads towards the bridge end got a bit srtipped, so i put some washers on there and then tightened it up - it never came loose again.
~kenny
kennydoe
04-23-2001, 05:15 PM
Make sure the teflon bushings on your bar are fresh too. Anything that's 'loose' in the whole chain will creat slop, eliminating flutter.
04-23-2001, 06:04 PM
jeffrey
Posts: 971 - iTrader: (
I find running fewer springs with the claw screwed in more 'stretching' the springs more gives it a loser/livlier feel.
It's worked for me. *shrug* I'm not saying it's right though.
Hehe. It's probably really bad for your guitar.
But in a nutshell I found that if I needed 4 springs with the claw run pretty far out, that if I ran three and ran the claw in a lot more stretching the springs, that it was smoother and 'looser' feeling.
Hope my drivel helps.
jeffrey
Visit jeffrey's homepage!
Find all posts by jeffrey
04-23-2001, 06:10 PM
Your drivel is right on the money. The more 'open' a spring is the less tension it takes to 'open' it further. The more 'closed' their position, the greater the amount of pressure is required to 'open' them.
04-23-2001, 06:21 PM
YaYoGakk
AAAAHHHHHHHHHH!!!!!!!!!!!
cry:
I broke the arm holder!!!! i over tightened it
it has never been replaced though and i see on the jemsite tech pages that it should be replaced every few years....oh well i just ordered the part from our
guitar shop
in town, shouldn't be any longer than 2 or 3 years getting here :sarcasm: lmao!! My 7420 still has all kinds of flutter but like you say everything is tight it's brand new, of course it has the lo-trs trem so i it won't be long before that stupid screw in bar will be rattlin' haha
Thanx guys
Alden
YaYoGakk
arm holder
claw screws
guitar shop
pro edge
string guage
string tension
trem claw
what trem is on the rusty cooley
how to tighten zr trem
problem frequencies when mixing
How to block ibanez trem
is my edge trem bar in all the way
12:37 AM
