Old 12-09-2012, 01:36 AM
Stealthtastic  is online
Posts: 424  -  iTrader: (3)
Re: UV7pwh Differences?
Originally Posted by Giabrone View Post
1200 seems a bit low. Mind you, I bought two uvpwh's (a 90 and a 91) for 1800 to 1900 usd each both in very good condition. Might consider getting rid of the 91 but you probably won't like the asking price . Regardless, the main differences I found between the two:
- middle PU poles have a different visual appearance/design
- finish on the neck feels slightly smoother on the 90
- markings on the back of the PUs don't have the "Dimarzio" stamp
- original edge on the 90 vs. Lo pro edge on the 91.
Woah, you're in Vancouver too huh? PM'd!
Old 12-09-2012, 07:59 AM
vy100  is offline
Posts: 450  -  iTrader: (2)
Reviews: 3
Attending to Ibanez official catalogs neck profiles changed from '90 to '91:
_ '90 catalog: neck profile was defined as a wizard, 17 mm thickness at first fret and 19 mm at 12th fret.
_ '91 catalog: it says neck profile is 20 mm thickness at first fret and 21.5 at 12th fret.
3 mm difference on the 1st fret and 2.5 on the 12th. You can check it out at Rich's site on "resources".
I do own a '90 7PWh with an edge trem and I can confirm that the '90 has a wizard profile neck but I have never played any other UV. My neck is so thin that there are only 3 mm of wood covering the truss-rod on the back of the neck and it broke longitudinal between the nut screws holes when the previous owner adjusted the truss-rod. I have had it professionally fixed. Maybe that kind of fractures made ibanez increase the neck thickness. I would like to know if that 3 mm increase between the 1st and 2nd years was true. Maybe Rich could clarify this...
Old 12-09-2012, 10:25 AM
Interesting, looks like tracking down a pwh with a thicker neck is probably a better idea then. Thanks for your help!
Can't wait to pick one of these up.
Old 12-09-2012, 02:17 PM
vy100  is offline
Reviews: 3
Mine is absolutely a player's dream due to its thin neck; maybe it is better idea to track down a '90 an take good care of it ;-)
Old 12-09-2012, 04:56 PM
Possibly haha! I'll see what I can nab.
Thanks again guys
Old 12-09-2012, 04:57 PM
derp...multipost oops
specs, uv7pwh
You think what of the UV7PWH? Dakhota JEM and Universe Guitars 10 06-15-2009 03:44 AM
WTB: UV7PWH yevetz Classified Ads: Ibanez JEM/UV Guitars 1 03-01-2008 04:46 PM
WTT: UV7PWH jim777 Classified Ads: Ibanez JEM/UV Guitars 4 10-11-2007 02:21 PM
UV7PWH johnboy30230 JEM and Universe Guitars 8 03-27-2007 03:05 PM
Wtb Uv7pwh ( Uk ) MOORWATER Classified Ads: Ibanez JEM/UV Guitars 3 12-20-2005 02:26 PM
