Volume difference between pickups selection
04-07-2009, 10:16 AM
hernan93
Posts: 9 - iTrader: (
Hello everybody:
I have a JEM7v bought in guitar center in 2006. My
pickups
have the DiMarzio Mark and each one of the five positions sounds great, but I note to much
volume difference
between the first 4 positions and the last one (with the pickup selector all down). is this volume difference normal in a JEM 7V Guitar???.
I usually play clean sounds with the first and second position, but if I choose the five position I have to compensate the volume playing less hard, or using my volume foot control, this is uncomfortable.
thank you in advance.
Hernán.
hernan93
Find all posts by hernan93
04-07-2009, 10:33 AM
bcrich1975
Posts: 162 - iTrader: (
Re: Volume difference between pickups selection
Have you tried adjusting the height of the pickups?
bcrich1975
Visit bcrich1975's homepage!
Find all posts by bcrich1975
04-07-2009, 11:07 AM
hernan93
Not, I had not thought of that. Thank you. I think (and hope) this can work. At the moment, my guitar is like I got it from GuitarCenter.
has the pickups's height significant relevance in the volume level??
11:24 AM
hernan93
04-07-2009, 01:28 PM
Timbaline
Posts: 508 - iTrader: (
Reviews: 7
hernan93
Yes the height of the pickup can significantly change the volume level.
Also, if your guitar is at "Guitar Center" level condition, that's not a great thing you might want to make a lot of major adjustments. Guitar Center has a tendency to murder guitars. When they sell you one they tend to "forget" to give you the tools, and they tend to "forget" that a free case comes with certain guitars.
Timbaline
Find all posts by Timbaline
04-07-2009, 04:08 PM
bcrich1975
Exactly what Timbaline said.
GC is not known for setting up guitars. Usually they are unpacked and displayed. You should set it up to your preferences and for ideal playability (or have it done professionally). The last new JEM I bought had a relativly poor setup. Although some of these factors can be blamed solely on shipping with humidity and temperature changes. String action was way too high, intonation was very slightly off, truss rod needed a slight adjustment as there was too much relief in the neck, tremolo angle and height needed adjusting (and then more adjusting as I tune mine to E flat). It's very important that the trem angle is set properly. And back to your problem the pickup height adjustments. Long story short, your new guitar will need some fine tuning to play at its best. Comb through Rich Harris' site "Ibanez Rules". There are very good setup tips there.
bcrich1975
04-11-2009, 01:07 AM
hernan93
Hi guys, thank you a lot for your help.
I tried with the pickup height and I can get some minor changes. I will take my guitar to the workshop.
please play your guitars (JEM 7VWH) and feel the volume difference between the pickups position changes. My guitar has a great tone, but the volume en positions 1 and 5 are louder than 2,3 and 4. I would appreciete if any do the test and write his own experience.
If somebody has no problem with the volume difference, pls indicate how many milimeters (or inches) of heigh is using in each one of his pickups. (just for be sure, this heigh is the distance between the top of the pickup and the string).
Thank you in advance.
H.
hernan93
04-11-2009, 10:08 AM
toneboy
Posts: 1,665 - iTrader: (
hernan93
When you split the humbuckers with the middle single you will get a difference in volume. That's kind of how it's designed. It's an easy and quick way to clean up a distorted sound without using your volume control or a footswitch. The PGMs are designed the same way.
toneboy
Find all posts by toneboy
04-11-2009, 10:41 AM
GilkyBear
Posts: 4,110 - iTrader: (
Yeah, in positions 1 and 5 you are using humbuckers, in 2,3, and 4, you are using single coils. This is why you have the volume difference. This is also why you have such a wide range of tones, but single coils just don't have as much output as humbuckers. No way around that.
If it is that much of a problem I would recommend figuring out a way to use only positions 1 and 5 on some songs and only positions 2,3,4 on other songs. Kind of like "Strat mode" and "Gibson mode".
GilkyBear
Find all posts by GilkyBear
04-11-2009, 10:49 AM
Algiman
Posts: 2,553 - iTrader: (
or you can bring all the levels closer together using a good compressor.
Algiman
Find all posts by Algiman
jem7v
pickups
volume difference
WHAT is the difference between js1000 and js1200
what difference do pickups make
why are evo 2 pickups so popular
how to change pickups on a jem
what pickups does chris broderick use?
Pickups selection for my Jem project
odissia
Tech: Setup, Repairs and Mods
04:28 AM
Pickups: How much difference do they actually make?
Wild_Child
Pickups & wiring
04:17 AM
Pickups selection for RG550
PinkSpId3r
Pickups & wiring
11:10 AM
Ibanez stock pickups .... whats the difference ??
athlon
Pickups & wiring
04:40 AM
UV7PWH pickups - Difference between new and old?
Akhenaten
02:48 AM
03:46 PM
