Go Back   Jemsite > Guitars and Gear > JEM and Universe Guitars
Old 12-20-2000, 07:11 PM
swiggy swiggy is offline
Posts: 46  -  iTrader: (0)
vwh neck opinions
can someone give help?
in your opinion, what is the best neck on the vwh, the 2000 ones or previous ones?
i would appreciate a lot of opinions so i can make up my mind.
Old 12-20-2000, 07:36 PM
jemsite's Avatar
jemsite jemsite is offline
Administrator
Posts: 8,667  -  iTrader: (5)
Images: 11
vwh neck opinions
I haven't seen a 2000 VWH neck but they can all be made the same by removing the finish on the rear of the neck. See the jemsite --> Guitar --> Tech/Setup area for details. IMHO that is critical for any JEM player if you have one with the poly finish from Ibanez.
I would not judge buying a VWH based on model year, i'd go by condition, price, the "used" factor and feel if you see it first hand. For example I'd personally take a '94 with great frets over a "new" VWH because it would be broken in already Good luck... glen
Old 12-28-2000, 02:23 PM
ellsobrien ellsobrien is offline
Posts: 80  -  iTrader: (0)
vwh neck opinions
I don't know about older necks, but I own two VWH's and the necks are really close but not exactly the same. The backs are sanded by hand (or so I have heard) from the factory, so one has a slight relief in the low 8th fret side that the other does not. You wouldn't notice it at first, but I did after a few weeks. I use that one as the back-up always, since it is a slight distraction when playing live.
I sugest you play a buch of 'em before you buy one since there are many differences you won't notice on just one or two.
Hope this helps.
Old 12-28-2000, 03:47 PM
tommy west tommy west is offline
Posts: 85  -  iTrader: (0)
vwh neck opinions
It still smokes every other guitar in existence in my opinion so minute differences in neck craftsmanship are minimal at best. Just get ya one, you will love it. Plus one a year or two old will save ya around 3 or 400$.
Old 12-28-2000, 07:22 PM
jay ratkowski jay ratkowski is offline
Posts: 2,091  -  iTrader: (7)
vwh neck opinions
I have a 2000 VWH... I didn't know there was any difference. *I have my neck sanded down to the wood though, so it's hard to tell.
Old 01-25-2001, 01:13 PM
shawn shawn is offline
Posts: 284  -  iTrader: (0)
vwh neck opinions
i have a 99 and a *2000, and the 2000 is cooler because they changed how they do the scallops--the scallops on the 2000 are from fret to fret whereas the 99's scallops were all the same size and left some of the area next to the frets unscalloped (which to me is quite unacceptable for a guitar of such caliber). *thats really the only major difference in which the make year will play a role--everything else is variable from guitar to guitar and has little to do with production year.
Old 01-25-2001, 09:04 PM
littlegreenman littlegreenman is offline
Posts: 2,625  -  iTrader: (4)
vwh neck opinions
I have a 2000 and it doesn't have any finish on the neck! *I got it brand new (Axe music ordered it and I was there when they first opened the box) *I also have a 2000 UV777BK and it does not have a finish on the neck at all either. *(same scenario with the music store)
The scallops on mine go from fret to fret as well, my old JEM777DY has all the same size scallops on it and I must admit, if not for playability, the scallops on my VWH look better.
Jeremy
Oh yeah, I know what the finish on the necks looks like and my 2 definitly do not have it but my friends DBK does!
Old 01-25-2001, 09:13 PM
Rich Rich is offline
Posts: 16,463  -  iTrader: (19)
vwh neck opinions
Better check the back of your neck again, the finish is there, it's just Matte now. Look at the serial # sticker and you can easily see it's cleared in. Alot of the 2000's I've seen have the much better scallops, but not all. Overall though they are much better. IMO it's only a visual thing because even on the thinnest scallops you can't get the string to the board.
Old 01-25-2001, 11:48 PM
vwh neck opinions
Hey Rich, I double checked the serial numbers on my JEM and UV, you can see the edge of the serial numbers very clearly AND....... *I can easily grab an edge with a finger nail and lift them so I'll be putting some clear on them to protect them, besides that, I've burnt the serial numbers into the wood in the neck pocket and the heel of the neck on the guitar. *
So is it just a total fluke that my Jem and UV have no clear on the necks???
The Jem gets played the most often (only about 45 hours so far probably) and you can already see the wood darkening on the back of the neck from sweating.
Oh well, I would have just sanded them anyway, this just saves me a little work.
Jeremy
BTW, I'm guessing the serial number's are screen printed onto the sticker as the one on my Jem is probably 3 times thicker than the one on my UV and you can scratch the lettering off if you aren't careful (one more reason to clear coat)
Old 01-25-2001, 11:56 PM
vwh neck opinions
Most think the matte clear isn't there because it looks like raw wood, but if it's not there at all, you've definately got some flukes on your hands, and if it's the same on both? I'm not totally convinced. Just too freaky a coinkydink!!
Old 01-26-2001, 01:27 AM
vwh neck opinions
Hey Rich, I'll borrow my buddies digital camera tommorrow if I can and take a pic for ya! *The only way I think it will show the edge of the serial number is if I lift it with an exacto knife blade or something though and I'm not totally sure I want to peel them up but I guess if I'm gonna clear coat them anyway it won't really matter. *I'll try to get the pics for you anyway.
Jeremy
p.s. the only thing I can think of is that when I ordered the guitars (I ordered both the same day), Efkay (the Ibanez distributor in Canada) told us that Ibanez was currently out of stock on the UV's and JEM's, whether this is true or not I don't really know but they said they would be doing another run soon. *It took like 4 months for the JEM to show up and about a week less for the UV (I believe) and they said it was because Ibanez was building them. *I don't know how true any of that was but..... all I know is both guitars showed up about the same time, both were ordered at the same time, and both have necks with no clear on them.
Old 01-26-2001, 01:35 AM
vwh neck opinions
Efkay doesn't stock very deep, and like Hoshino, is basically sold out untill the nect import on many models, &vwh's are at the top of that list. I'm not saying you're not correct, just that it's a pretty freaky coinkydink if both models actually don't have any clear on the necks. It is supposed to be there. I have seen some very LIGHT coats, and with the matte it's almost impossible to tell it's there, but I can usually always find some sign of it being sprayed to some degree,
ESP LTD M-103 Flame Maple Electric Guitar See-Thru Black
As low as $329
at 4 sellers
Hal Leonard Nirvana Guitar Chord Songbook
As low as $9
at 9 sellers
Members with more than 50 posts don't see this bar
Gibson Custom 1956 Les Paul Goldtop VOS Electric Guitar Antique Gold
As low as $3699
at 3 sellers
ESP LTD MH-53 Electric Guitar Black
As low as $295
at 3 sellers
Seymour Duncan SA-6 Mag Mic Active Acoustic Guitar Pickup
As low as $229
at 14 sellers
Fender 9050ML Stainless Flatwound Bass Strings
As low as $23
at 8 sellers
Hal Leonard Guitar Scales Poster
As low as $4
at 8 sellers
Dean Markley 2555 Blue Steel Heavy Electric Guitar Strings
As low as $6
at 8 sellers
Ibanez Artcore AF95 Electric Guitar Black
As low as $479
at 12 sellers
Fulltone '70 Fuzz Guitar Effects Pedal Dark Blue
As low as $144
at 16 sellers
Ibanez Artcore AGS83BATF Electric Guitar Antique Burst
As low as $450
at 21 sellers
Alfred Guitar World How To Play Hard Rock & Heavy Metal Guitar (DVD)
As low as $7
at 22 sellers
Taylor 200 Series 210ce Left-Handed Dreadnought Acoustic-Electric Guitar Natural
As low as $999
at 3 sellers
Planet Waves Guitar Strap Shoulder Pad
As low as $7
at 5 sellers
clear coat, music store
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
