View Poll Results: Which Edge has the best flutter?
Equally good flutter 4 11.11%
Origional Edge 28 77.78%
Edge Lo-Pro 4 11.11%
Voters: 36. You may not vote on this poll
Old 09-18-2007, 06:15 PM
Devon8822  is offline
Posts: 389  -  iTrader: (3)
Smile
Which Edge has the best flutter? or are they both equally good at producing flutter?
Old 09-18-2007, 06:18 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Re: Which Edge has the best flutter?
Original Edge.
Old 09-18-2007, 07:20 PM
andy7jem  is offline
Posts: 6,504  -  iTrader: (0)
Original Edge
My RG20th flutters amazingly
Old 09-18-2007, 07:43 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Original edge on my guitars. Its a much stronger, longer lasting flutter. My lo pro equipped guitars had less all around, and my original floyd had very little. I dont flutter alot with my kahler equipped guitars, and have a few of them blocked off even now. Just a quick note, though i think the schaller/floyd rose 2, flutters better than the original floyd.
Old 09-18-2007, 09:33 PM
Dee  is offline
Best flutter I've had was with Original Floyd's, mostly on 80's Kramer's, etc.
Old 09-18-2007, 10:38 PM
Crazy! What type of studs were in those kramers? Ever see the older ones with the wood screw type struds with no bushing/collar whatchamahoosit?
Old 09-18-2007, 10:57 PM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
the edge i have now doesn't quite flutter as well as the lopro i had on a Jem7dbk a while back.. though now i have heavier strings too so i guess that could be why..
Old 09-18-2007, 11:20 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
who wants to flutter anyway? am i the only one that uses a it for actual vibrato?
Old 09-18-2007, 11:30 PM
BozTheK  is offline
Posts: 244  -  iTrader: (0)
Just thought I'd let you know that the DBK's flutter is quite good! But only when you have new strings, either that or there is something wrong with my bar.
Old 09-18-2007, 11:59 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Someone needs to move this poll to the tech section.
The Original Edge has the best flutter IMO.
Jimmy
Old 09-19-2007, 12:32 AM
TicTac in my eye  is offline
Posts: 600  -  iTrader: (0)
Jimmy
I just ate a crab cake!!!!
The Orginal Edge!!
Old 09-19-2007, 04:19 AM
Sunrise  is offline
Posts: 114  -  iTrader: (0)
I guess it could come down to condition/setup more.
But I would say the Edge Pro is the best of the edges, however I get the best by a mile from a OFR on an ESP, but maybe this has something to do with the arm being tightly screwed in as opposed to pushed in and held by bushes which will have some cushioning in comparison.
Old 09-19-2007, 05:51 AM
Eco  is offline
Posts: 693  -  iTrader: (0)
From what i've played i actually like the Edge Pro best for flutter.
Mite just be me tho
Old 09-19-2007, 06:07 AM
Devo  is offline
Posts: 1,483  -  iTrader: (20)
It mostly depends on the sharpness knife edges, but other factors like the mass of the trem behind the knife edges, string elasticity also make a difference.
The edge is the shortest of the lot with the majority of the mass closest to the knife edges so it requires less energy for the tremelo to change direction, from going up to going down... hence it should flutter longest and best.
Old 09-19-2007, 06:30 AM
i change my vote. after messing with my spalted RG's edge all day i think it flutters very well.
though i must say, Vai gets by pretty well on a lopro....
equipped guitar, floyd rose
edge pro to lo pro rya JEM and Universe Guitars 42 05-11-2011 03:54 AM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
Why doesn't the Lo-Pro flutter as good as the Edge? Dee Tech: Setup, Repairs and Mods 15 08-21-2006 02:03 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
