Old 05-22-2007, 02:22 PM
ohioplayer  is offline
Posts: 265  -  iTrader: (6)
Which Trem for a Christopher Woods Jem Body?
I was told to go with an Ibanez Edge. But then I have seen Ibanez Edge, Edge pro, Edge Pro 6, etc. I am new to Jem's and please forgive my ignorance, but what is the difference, if any?
Old 05-22-2007, 02:35 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
Re: Which Trem for a Christopher Woods Jem Body?
I think he builds them for Edge or Lo Pro Edge, so it will then be based on profile or if you like to see the allen key extend into the lion claw section or not.
you should check with what Chris is building for you since the new Edge Pros are different routings and you can not use the older Edges.
Also I think the neck pock size on JEMS changed in 05, from 46mm to 48mm
Old 05-22-2007, 03:00 PM
I would prefer the allen keys to be extended into the lions claw. I have the body in hand, so I will measure up the trem and neck pockets and post the measurements here.
Old 05-22-2007, 06:14 PM
tobias.  is offline
Posts: 321  -  iTrader: (16)
-> definitely an edge. depending on the claw you might have to shorten the screws 2-3mm.
regards
tobias.
Old 05-22-2007, 06:39 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
http://www.jemsite.com/jem/trems.htm
Old 05-23-2007, 01:53 AM
Would a standard Floyd work in the meantime, or, as I believe, are Edge trem's wider? I need one for this:
Anyone heard of (and this name could be wrong): J.R. Manoony? His name is on the neck pocket (although it is hard to read and the last name could be Mano***, Manooay, Manogny).
Old 05-23-2007, 07:33 AM
Images: 1
I'm pretty sure edge trems are wider. Also imo the edge is better than an ofr in certain ways. Plus the ofr would look very wrong in that guitar since the route will be so much longer and I think wider than an ofr route
Old 05-23-2007, 01:17 PM
Awesome. Thanks for the info. I am off to Pierre's site to search for an Edge now.
Old 05-24-2007, 10:57 AM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
The Edge should work great but my preference would have been for the Lo Pro as it is nice to have the allan screws in front of the tail rather than in the claw. I block the trem and the allan screws behind the tail get in the way when I'm doing maintenance and restringing.
Let us know how it goes for ya.
edge pros, edge trem, edge trems, neck pockets, pro edge
Buying a Swirled Jem Body daz5150 JEM and Universe Guitars 2 05-02-2007 12:14 PM
Legacy One JEM Body review Major Tom Other 6-string Guitars (non-Ibanez brand) 52 02-12-2007 05:36 PM
STUFF FOR SALE: Jem body, guitars, pedal... Davey Classified Ads: Guitars and Gear 22 01-27-2007 04:12 PM
Jem Trem Setup Help Please. Chris From Singapore. Tech: Setup, Repairs and Mods 4 07-05-2005 01:10 PM
New here/ jem body TheSacredShredThing JEM and Universe Guitars 0 01-09-2005 02:12 PM
