Old 04-22-2008, 06:43 PM
mooro  is offline
Posts: 167  -  iTrader: (5)
Wiring Diagram for coil tap on jem?
plan B to changing my evo's is to wire them so that I can coil tap off the tone control as is possible on the new S5470F
from ibanez site "The True Duo Blast pickups on the SV Prestige maximize the True Duo advantage. The special wiring enables switching the PU configuration between H-S-H and S-S-S by one push/pull action."
Has anybody a wiring diagram for this ?
Old 04-26-2008, 02:12 AM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Wiring Diagram for coil tap on jem?
You can do it with a push-pull pot/switch. Just wire the center taps of the switch to ground and wire the black/white pair of each DiMarzio humbucker to the upper lugs of the switch so when you pul the knob out, you short one coil to ground for single coil operation.
coil tap, wiring diagram
My JEM wiring messed up? sveto Pickups & wiring 5 04-01-2008 05:45 PM
Looking for wiring diagram for RG8527 & other J-Customs Dan_H Pickups & wiring 2 10-05-2006 11:49 AM
jem 7 wiring diagram questions Koss Pickups & wiring 0 09-08-2005 01:21 AM
JEM10th Evolution Wiring Diagram..... gerca Pickups & wiring 6 11-18-2002 05:59 PM
Double Edge wiring diagram needed... - Changing pickups in S armadillo Tech: Setup, Repairs and Mods 6 03-07-2001 10:04 AM
