Old 05-10-2007, 01:44 AM
cmd130  is offline
Posts: 233  -  iTrader: (0)
WOULD THIS IDEA WORK?.....HELP!!!
Alright guys, I know this is in the wrong place but I need your help! I hope I can explain this correctly and that u can help me. I just got a Rocktron Utopia G100 for my birthday and I love it. The only thing that bothers me is that u can't jump between presets easily cuz it only has 3 switches, one for preset recall and two to scroll up and down thru the presets. I use a solid state amp and it sounds alright for my cleans but the distorton sucks. The amp has 2 inputs on the front, one low gain and one high gain. I was thinking of getting an a/b switch and running the "a" channel into a chorus pedal(the only effect I use for cleans) and then into the high gain input for my clean sound and running the "b" channel into the utopia then into the low gain input. That way I could still jump easily between clean and dirty tones. I love the recto-fried preset and would use that as my dirty tone most of the time but would also use a few others from time to time. The amp has a great sounding spring reverb that I always keep set on 4 for both clean and dirty tones.
Is this setup even possible? If not, do u have any suggestions? u guys have given me great advice in the past so I know I can count on y'all!!
Old 05-10-2007, 07:02 AM
EL-CeeDee  is offline
Posts: 484  -  iTrader: (0)
Re: WOULD THIS IDEA WORK?.....HELP!!!
Hmm,. not sure.
If you can make the low gain input's level the same as the high gain input, it shouldn't be a problem.
If your amp has an effects loop you could go with a little bit different setup.
Put a loopswitcher in there ( lehle Dloop is nice and affordable ).
Make a loop from amp input to effectsloop out.
Another from rocktron input to output
connect looper to effects loop input ( in addition to any effects you have. )
So :
Loop 1 : Amp clean channel
Loop 2 : Rocktron device
Output : to effects like chorus, delay, whatnot to effects return.
Big plus is that the rocktron sound goes directly to the poweramp. Ofcourse, you could connect the chorus in loop 1 as well.
Old 05-10-2007, 10:48 AM
Ranz 777  is offline
Posts: 686  -  iTrader: (0)
Images: 16
I use to have a similar problem..........long time ago. I had a Marshall pre-amp running into a Mos-Valve power amp which powered 2 Marshall 4x12 cabinets. I had a BBE, Alesis EQ, Zoom effects processor, etc. thru the effects loop of the pre-amp. From clean to dirty I had to step on the pre-amp pedal. To change effects, I had to step on the Zoom pedal.......however many times it took to get to an effect I wanted. Plus..........the Zoom had like a second of silence switching between effects.............drove me nuts. Tap dancing on my pedals and having these little bits of silence everytime I switched effects! I considered getting another amp with an A/B switch for my clean.............
It became easier & cheaper to just ditch the processor and I got a delay stomp box. Delay is the only effect I really use anyway from time to time. That way all I had to step on was clean/dirty...........delay on/off.
Of course...............now................Im back to using processors again, but its all in-line thru the mixer and into the recorder.
amp input, chorus pedal, power amp, solid state amp, spring reverb, stomp box
HAHAHA heres an idea that so silly it would work great ibanezcollector Off-topic / Miscellaneous 42 02-02-2006 01:00 PM
Good idea: Cleaning your pickups. Bad idea: Using steel wool Kremlin Tech: Setup, Repairs and Mods 7 04-11-2003 11:11 AM
New custom 8-string idea.. Jay Cal Other 7-string Guitars 18 09-04-2002 11:55 PM
Brand New Finish - got an idea...need an idea. RSVampire Tech: Setup, Repairs and Mods 5 03-22-2002 11:39 AM
tonight's guitar tech and mod work - my RG520Q is a tone MON AJ Love Tech: Setup, Repairs and Mods 4 09-04-2001 08:55 PM
