Old 05-24-2007, 05:38 PM
ohioplayer  is offline
Posts: 265  -  iTrader: (6)
Would this work (Neck Conversion)
I saw this photo:
I had given that some thought with the 550/570 neck I have to use it with my CWG swirl. I was afraid that the intonation would be off and never gave it much more thought. Now that I see this photo, I wonder ... would this work and still keep the intonation correct? if so, I can stop looking for a neck and focus on a trem.
Old 05-25-2007, 01:02 AM
Re: Would this work (Neck Conversion)
Anyone? Would like to get cracking on this this weekend. Thanks guys!
Old 05-25-2007, 09:45 AM
djohns74  is offline
Posts: 580  -  iTrader: (0)
There's no real reason why it wouldn't "work", but I'm not convinced it would be worth the effort to get it right.
Old 05-25-2007, 11:10 AM
resha  is offline
Posts: 149  -  iTrader: (0)
Well I don't think you should be worried about it.
Intonation is a matter of "bridge posiotion" (ie saddles) so, unless the converted neck has a big difference compared to the original one (a fret off-axis of cms...), you just need to check your intonation like you'd always do when unscrewin the neck
Old 05-25-2007, 07:45 PM
Currently I just cant afford a new neck for it and since this neck was included in a trade, if I screw it up, it cost me nothing. if it works, it saves me $$$ and since I can't get an answer from Chris Wood's people (sent two emails, no response), I have to use what I got ... unless someone here needs a 570 neck, I'm stuck with it ...
Old 05-25-2007, 10:00 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
I don't see why it shouldn't, it worked for Steve.
Jimmy
Old 05-25-2007, 11:58 PM
bulletbass man  is offline
Posts: 121  -  iTrader: (0)
atleast try it.
If it doesn't work no real loss.
If it does yay
Old 06-11-2007, 04:45 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
The problem is the heel. The AANJ neck has the heel that ends at the last fret. The older non-AANJ heel ends before the 22nd fret so intonation will be out the window.
aanj neck
Would a neck pickup work in the bridge OK? dannymills Pickups & wiring 4 01-19-2007 09:06 PM
Neck angled wrong on 3120? TheJazzTerminator Tech: Setup, Repairs and Mods 2 06-02-2006 08:16 PM
for trade , ibanez usrg30 j.arledge Classified Ads: Guitars and Gear 2 03-07-2006 10:14 PM
Painted neck? Sanded neck? Drache713 Other 7-string Guitars 28 12-25-2005 12:45 AM
Jem 7DBK neck confusion... Spagbol JEM and Universe Guitars 2 12-30-2002 05:48 AM
