Old 05-12-2007, 11:06 PM
Homeless  is offline
Posts: 30  -  iTrader: (1)
A neck question
I've been trying to search out this answer and haven't found anything concrete so I decided to break down and ask.
Does an RG520 use the same neck as an RG1570? If not, what are the differences?
Thanks and pardon my ignorance.
Old 06-10-2007, 10:21 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: A neck question
Same neck on rg520, 550 and 570. Usually when you remove the neck from any of those models, you will find either RG550 or RG570 stamped on it regardless which model guitar you have. #2 after the neck stamp denotes Wizard II profile. Most are Wizard profile. Some RG470 years actually have RG550 necks on them. The newer "prestige" RG models are also likely to have a neck stamp that does not match the model(but agin, the necks are the same).
Jem7PBK - Question about the neck Martijn JEM and Universe Guitars 3 01-03-2007 09:04 AM
Wizard II Neck Nut Replacement Question Dark Alone Tech: Setup, Repairs and Mods 10 09-13-2006 10:22 AM
Painted neck? Sanded neck? Drache713 Other 7-string Guitars 28 12-25-2005 12:45 AM
Neck profiles question from an Ibanez newbie Anonymous Other Ibanez Guitars (including Premiums) 3 05-06-2004 09:26 AM
Different Jem's = Different Neck profiles? - a question rega jem7vwh JEM and Universe Guitars 13 01-31-2001 04:14 PM
