Old 01-16-2009, 08:37 AM
hindlewind  is offline
Posts: 39  -  iTrader: (0)
Bare knuckles in a RG3120 VV Prestige
Hi Guys,
In a weeks time i'm going to buy some Bareknuckle Crawlers to in my ibanez.
On the website there are a few things i'm unsure of:
Spacing: 50mm or 53mm
Cover: I'm going for Nickel Cover (I use pure blues nickles wound strings, Choosing these covers instead of chrome won't have any adverse effects?
Conductor: 4 or Braided 2. I'm guessing 4 is standard?
Leg: 1/2" or 1/4" ? Not sure here.
I did notice the screw mounts are square so a little bit of filing is required but that'll be no problem.
Thanks for the help, I'll upload a click to show you they sound when they arrive.
Old 01-16-2009, 08:44 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Re: Bare knuckles in a RG3120 VV Prestige
Spacing 53 mm (F spaced essentially)
No tone problems with the nickel, but it does age and tarnish. That looks great on something like a Les Paul but might be odd on your guitar.
Conductor: 4, if you want to be able to split the pick ups as per the stock wiring
Legs, not sure - measure the stock ones!
Old 01-16-2009, 08:57 AM
Thanks for your help, I'm guessing i would measdure the bottom actual pickup to the bottom of the mounting.
I'll see when i get home thanks again.
Old 01-16-2009, 09:21 PM
NeglectedField  is offline
Posts: 945  -  iTrader: (0)
I don't understand why BK don't have these "Crawlers" on their website.
Old 01-17-2009, 01:13 AM
Riverdragon  is offline
Posts: 324  -  iTrader: (3)
E-mail Tim at BKP and ask him what legs size you will need. Probably short for an Ibby. 53mm, 4 conductor and also if you request it they will do triangular tabs to fit without modification. Although I have a sqaure tabbed BKP in my RG2610 and although it's quite tight it did fit. Also the Crawlers certainly are on the BKP site under the signature series pickups.
Old 01-17-2009, 08:32 PM
skhan007  is offline
Posts: 37  -  iTrader: (0)
I've been real interested in hearing these pickups, but their from the UK, right? Who sells them in the US? Any clips that anyone has made?
Old 01-17-2009, 10:53 PM
bareknucklepickups.co.uk plenty of clips on their forum. Forum member raglor, also known as Zimbloth on sevenstring.org is a BKP dealer and a real good guy. If you are interested pm him and he can get you whatever you want. Although you may have more luck on ss.org. I'm not sure how often he is over here. Although he is at NAMM right now.
Old 01-17-2009, 11:34 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
Got a C-pig from Jason @ Peerless Tone. Cool guy but it takes @1 month to get it from the UK to your mailbox. Well worth it though
Reg
Old 01-22-2009, 07:07 AM
I went for a calibrated crawler set.
I appreciate the help and will update with pics in about 2-3weeks when i've put them in.
FS: RG2610E Prestige w/ Bare Knuckle Pickup & OHSC *MINT* raglor Classified Ads: Guitars and Gear 2 12-08-2008 04:52 PM
Bare Knuckles Warpig in a S-470 Morpheus Pickups & wiring 5 09-06-2008 06:54 PM
Bare Knuckles Rebel Yell (Steve Stevens model) pickup set? red5 Gear and Equipment 7 05-19-2006 06:21 PM
RG3120 Prestige sirbrandon101 J-Custom, USA Custom & Prestige Ibanez Guitars 5 05-01-2006 03:00 PM
RG3120 Prestige sirbrandon101 J-Custom, USA Custom & Prestige Ibanez Guitars 1 04-30-2006 09:28 PM
