Old 09-25-2006, 01:56 PM
guitardude67  is offline
Posts: 51  -  iTrader: (0)
Bridge question?
I own a ESP MII and it has orginal floyd rose on it and GHS strings and Iam noticing that its holds tune better than my RG2550 with Edge Pro bridge and D'addarrio strings.Could it possibly be the strings?I know from talking to many techs they say GHS or Ernie ball are great for a floyd system.Opinions welcomed!
Old 09-25-2006, 02:00 PM
moebius  is offline
Posts: 2,041  -  iTrader: (0)
Re: Bridge question?
I would think the culprit would be something else. Once the strings are properly stretched if the bridge and locking nut are doing their job, there should be no problem. I would look at the bridge and nut first before blaming the strings. Just my two cents.
Old 09-25-2006, 02:07 PM
Originally Posted by moebius View Post
I would think the culprit would be something. Once the strings are properly stretched if the bridge and locking nut are doing their job, there should be no problem. I would look at the bridge and nut first before blaming the strings. Just my two cents.
Thanks for reply!I did stretch them and everything looks fine.It's not badly out of tune just a touch flat,honestly with the floyd and ghs strings that thing never moved the only time i would re-tune is when I was doing string changes.I guess floyd is just better??
Old 09-25-2006, 02:25 PM
Planeflux  is offline
Posts: 210  -  iTrader: (0)
Perhaps the problem is caused by the non-locking studs the EP is equipped with? More info about the issue is detailed here.
Old 09-25-2006, 02:33 PM
Great link thank you that has to be it.Like I said its not terribly bad but somewhat noticeable,guess I was spoiled with the floyd...
Old 09-25-2006, 08:05 PM
Phishphood42  is offline
Posts: 540  -  iTrader: (0)
Make sure the bridge is level with the body. If it is pulling forward or back it wont return in tune.
Old 09-26-2006, 03:14 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
+1
Regards
André
Old 09-26-2006, 10:03 AM
madpickin03  is offline
Posts: 531  -  iTrader: (1)
And lube the studs using lipbalm/chapstick, surprisingly it'll improve the return back to pitch.
Old 09-26-2006, 12:31 PM
buddroyce  is offline
I'm not too sure if that's a major difference between the EP and the OFR since the OFR studs aren't locking studs either.
Old 09-26-2006, 01:16 PM
I wasn't aware of that. Thanks for pointing it out.
Old 09-26-2006, 02:13 PM
MetalZone  is offline
Posts: 273  -  iTrader: (0)
btw, did u happen to find chapstick in malaysia? i got mine from rich lol.
Old 09-26-2006, 02:51 PM
Like I said its not that bad just not as good as OFR,Iam gonna put the GHS on next string change should help...
Old 09-27-2006, 07:17 AM
Nope, i use a petroleum jelly based odorless lipbalm, got it from my sis who bought it frm the US, works wonderful. You could probably find a chapstick in Ampang, probably in Great Eastern Mall, but the closest of our product to the chapstick is the LipIce, lol, its not good coz its water based and smells funny
Old 09-27-2006, 04:59 PM
smells funny
then you wouldn't wanna kiss someone that has that on LOL.
edge pro bridge, ernie ball, esp mii, floyd rose, locking nut, locking stud, locking studs
(long) PU to fatten/warm-up: RGT3120 bridge JuanCaca J-Custom, USA Custom & Prestige Ibanez Guitars 4 09-13-2006 03:30 AM
Bad horsie 2 question and Amp Question snorkthesick Gear and Equipment 1 04-11-2004 05:56 PM
JS900 Question! EXCrosslink JS (Satriani Model) Ibanez Guitars 8 06-18-2002 07:14 PM
Help installing a bridge - And where can I buy a Lo-Pro Edge Kremlin Tech: Setup, Repairs and Mods 8 07-27-2001 06:35 PM
New P'ups in my JEM - ...bridge and middle replaced... kennydoe JEM and Universe Guitars 2 04-10-2001 11:55 PM
