Old 03-28-2006, 09:15 PM
gemini8026  is offline
Posts: 348  -  iTrader: (5)
Comparing necks, Ultra vs Wiz 1 and 2
Hi guys, im lookin at an high end RGT with an ultra neck. Ive owned a few Wizard and Wiz 2 necks ( i prefer the wiz 2 as its thicker) and im curious how the ultra plays into the equation? What is it's feel and profile relative to the Wizards?!
Radii/width/thickeness, and general feel. Any one love it, hate it, or prefer it over the Wizards?!? Thanks for any input!
Old 03-28-2006, 09:17 PM
Unknown Doodl3.2  is offline
Posts: 279  -  iTrader: (1)
Re: Comparing necks, Ultra vs Wiz 1 and 2
The ultra neck is thicker then the wizard and same thickness as wizard 2 but feels a lot better imo...
Old 03-28-2006, 11:18 PM
vmx23  is offline
Posts: 124  -  iTrader: (0)
The Ultra neck is noticeably thicker than the Wizard II. I don't really like it though, feels like those fender and gibson necks. I will stick with the wizards.
Old 03-29-2006, 02:55 AM
gargamelesp  is offline
Posts: 13  -  iTrader: (0)
I was torn between buying a neck thru RGT3020 with an ultra neck profile, and a bolt on RG3120 with the wizard neck. The ultra was definitely more chunky than the wizard. In terms of playability, i prefered the wizard.
Old 03-29-2006, 05:41 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
OK these are the specs (all in mm):
Width (Nut/24th), Radius, Thickness (1st/12th)
Ultra --- 42/56, 430, 19.5/21.5
Jem ---- 43/56, 430, 19/21
Wizard - 43/56, 430, 17/19
Wizard II 43/56, 400, 19/21
the Ultra is supposedly very close to the original Jem, but the Jem got increasingly more Wizard like. (From the DBK specs on this site: "kind of a Wizard neck at the nut but not at the 12th fret")
You also have to take into account the general shape, luckily for us the names correspond to the shape, so:
Ultra, Viper, Wizard = U-shape, V-shape, W-shape.
What most companies refer to as D-shaped is U-shaped in Ibanez terminology.
The W has a flat bottom, the V a pointy bottom, the U is round.
The Ultra is only a hair thicker than the Wizard II, but will feel differently. I recently tried an RGT3020 and I found the neck way to thick and round for my liking, but according to Rich the neck on the RGT320 is a lot flatter. For comparison, I own a Jem777DY (orig.Jem shape) and a Jem90HAM (Wizard-like)
http://www.jemsite.com/forums/showthread.php?t=42610
Old 03-29-2006, 10:40 AM
Chris From Singapore.  is offline
Posts: 462  -  iTrader: (0)
I've played ibanez guitars with the Ultra, (I believe it was the JPM100s) as well as wizards (Various RGs and PGM series). Measurements and technicalities aside, to me the Ultra neck feels slightly thicker and narrower. The Wizard neck, thinner and wider...especially on those maple fretboard PGMs.
I prefered the Ultra profile, I love having the grip of a thicker neck.
If you have the opportunity to try one out at your location I strongly suggest you do so before making your purchase.
Old 03-29-2006, 01:51 PM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
I like the Ultra too, but prefer the wider nut. A JEM would probably be perfect, but I don't like the look, the 24 frets, the body shape, or the cost. I need a bolt-on 22 fret Jem profiled neck..
Old 03-29-2006, 03:20 PM
Man I really miss the old jem neck profile...
body shape, ibanez guitars, jem neck, jem neck profile, maple fret, maple fretboard, neck thru
F/T: Peavey Ultra 60 Watt 1x12 amp For...... Jackson Soloist Classified Ads: Guitars and Gear 0 02-13-2005 10:51 PM
Ultra neck on J's - Same as old Ultra neck ? 6828 J-Custom, USA Custom & Prestige Ibanez Guitars 1 01-13-2003 06:29 PM
Getting used to thin wizard necks - fat necks vs thin necks, Guitarlos2 JEM and Universe Guitars 44 10-15-2001 06:15 PM
Jem vs. the Les Paul Vaiworship JEM and Universe Guitars 25 10-11-2001 03:29 PM
Necks and Bodies - Necks and Bodies sebastian JEM and Universe Guitars 20 03-29-2001 10:50 AM
