Compound radius fretboards
03-22-2009, 05:56 AM
adriandavidb
Posts: 118 - iTrader: (
Not sure if this topic should go here, or in the JS thread?
The Ibanez website states something that suggests that the 'Prestige' necks are fitted to all but the 'bog-standard' (cheapest) JS, are equiped with
compound
radius
fretboards i.e the camber radius increases from nut to neck, to facilitate string bending at low action heights, without 'choking-off'. Is this the case?
Also do the wizard necks fitted to other Ibanez guitars have them too?
adriandavidb
Find all posts by adriandavidb
03-22-2009, 09:31 AM
GuitarBizarre
Posts: 1,184 - iTrader: (
Re: Compound radius fretboards
The JS necks are multi radius, but that refers to the BACK of the neck.
Compound radius means the fretboard itself starts off with a small, more curved radius at the nut, and flattens out going down the neck, to faciliatate lead playing further down.
Ibanez generally do not produce compound radius necks, preferring to stick with a constant radius all the way down. On wizard necks that will be a 430mm radius, so very flat. On a JS neck, it will be a little wierd all over, since those necks are digital recreations of Joes favourite time worn neck.
GuitarBizarre
Find all posts by GuitarBizarre
03-22-2009, 09:55 AM
Rayle
Posts: 16 - iTrader: (
Could someone please explain how the radius is measured?
I understand other manufacturer's neck radius specs, eg. Fender where a 9" radius means the curve of the fretboard is the same as an arc of 9" radius circle, but have no clue how the flat neck of an Ibanez has a radius of 430mm!
Sorry for being off topic.
Rayle
Find all posts by Rayle
03-22-2009, 11:25 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
The JS neck has a compound radius on the fretboard and multi radius on the back of the neck.
Jimmy
jb4674
Find all posts by jb4674
03-22-2009, 11:30 AM
timi_h
Posts: 1,104 - iTrader: (
Rayle
cos ibanez necks arent quite flat, they have the same curvature as a circle of radius 430mm...
obviously, a circle that big is going to seem quite flat over a section as small as the width of a fingerboard.
timi_h
Find all posts by timi_h
03-22-2009, 11:35 AM
ColinMmmmm
Posts: 1,068 - iTrader: (
Rayle
The metric system?????
430 mm is ~17 inches . . .
ColinMmmmm
Find all posts by ColinMmmmm
03-22-2009, 07:25 PM
adriandavidb
GuitarBizzarre, I know very well what compound radius means, as you can see from reading my post, I mention fretboard, NOT the back of the neck! Thanks for your input anyway.
jb4674, any idea what the variation in radius is from nut to to top end??
adriandavidb
03-22-2009, 07:45 PM
Posts: 19,352 - iTrader: (
The compound radiusing and "digitized" marketing is about the back of the neck only. The fretboard is 250mm radius 1-22.
This belongs in the JS forum.
03-23-2009, 04:53 AM
Rayle
Wow, how embarassing. My (at the time) fried brain led me to believe that 430mm = 4.3cm instead of 43cm, hence the confusion!
Rayle
camber
compound
radius
what is a multi-radius guitar neck
how to file a compound radius neck
warmoth compound radius comfortable?
what is the radius on a 1980's jap strat
JS neck fit a 540 radius?
rubbing compound - clear finish
jlander
Tech: Setup, Repairs and Mods
03:37 AM
compound radius for fingerboard and frets?
SilverSurfer2
01:18 AM
Compound radius fingerboard, any Drawback?
cowcowcow
01:10 AM
JS1000 compound radius - What are the exact specs
shred4Him
01:53 PM
Compound/custom radius on JS and Warmoth necks - Is it reall
edo
10:04 AM
04:27 PM
