Re: difference between 1570 and 1550
that's all it means. front routed guitars have a pickguard to hide the routing and to mount the electronics. rear routed guitars have body mounted electronics and cavity/control covers on the rear of the body.
the difference with the pickguards you would use for the two arises from the fact that with a rear routed body, the nuts etc. are already mounted to the body. also, the 5-way switch would run out of travel without an enlarged opening.
have a good look at the way a 77fp pickguard works.
