Edge pro trem studs won't turn?
04-24-2009, 04:00 AM
Sonicboom
Posts: 9 - iTrader: (
Hey all!
I recently purchased an RG1570 Prestige which I got back yesterday after a full set up. I asked for the
action
to be set really low, get a fret dress etc...
However, after bringing it back home I was pretty disappointed to find out that the action was a lot higher than I expected (a clearance of around 3mm on the 12th fret, low E string).
So I went about trying to lower the bridge, but even with a fairly large amount of force applied, the trem
studs
(screws?) won't budge :/
Am I doing anything wrong/is there anything else i have to do before turning the studs?
Also, if i do manage to bring the action down to about 1.8 mm at the 12th, will that mess up the intonation and bridge angle?
Thanks in advance for the help
Sonicboom
Find all posts by Sonicboom
04-24-2009, 04:02 AM
Homebake
Posts: 1,041 - iTrader: (
Re: Edge pro trem studs won't turn?
does the guitar have a locking stud mod?
Homebake
Find all posts by Homebake
04-24-2009, 04:03 AM
Posts: 19,352 - iTrader: (
Is the stud 3mm or 4mm Allen?
04-24-2009, 04:06 AM
Sonicboom
Ah i'm not sure actually. How do i find out if it's a locking stud and if it's 3 or 4mm? This is my second guitar and the first one with a floating bridge...and i'm still very confused :/
Sonicboom
04-24-2009, 04:17 AM
What size is the Allen wrench you used...
04-24-2009, 04:39 AM
Sonicboom
http://i208.photobucket.com/albums/b...t/DSC03963.jpg
One on the right, don't know what size it is sorry
Pics of the bridge if it helps...
http://i208.photobucket.com/albums/b...t/DSC03953.jpg
http://i208.photobucket.com/albums/b...t/DSC03956.jpg
Sonicboom
04-24-2009, 04:42 AM
3mm.
The bridge looks as low as it goes. Your problem is going to be in the neck pocket, which would be very strange if it needs a neck shim, EP guitars typically never do.
04-24-2009, 04:53 AM
Sonicboom
Ah alright. So i'll have to go to a tech and get it checked up then?
Sonicboom
04-24-2009, 06:09 AM
nuno
Posts: 4,725 - iTrader: (
on a side note... is that guitar intonated? look at the saddles pattern, it's a straight row!
nuno
Visit nuno's homepage!
Find all posts by nuno
04-24-2009, 06:25 AM
Sonicboom
hmm yeah...looks like it was a pretty mediocre set up. Wasn't even completely in tune when i got it back (all strings were too sharp). It was a free set-up because i bought the guitar from that store...was supposed to cost 100 bucks apparently
Better take it back tomorrow then.
Thanks for the help though
Sonicboom
04-24-2009, 06:28 AM
Vim Fuego
Posts: 908 - iTrader: (
3mm.
I needed to put a shim in the neck pocket of my Jem to get the action as I liked it, so you may need to do the same.
Is the neck pretty straight or does it have a noticable "bow" to it, as that will effect the action? Check the space between the strings and the frets while holding the string on the first and last fret. there should be a small gap.
http://www.ibanezrules.com/tech/setup/truss.htm
and
http://www.ibanezrules.com/tech/setup/action.htm
Jim
Vim Fuego
Visit Vim Fuego's homepage!
Find all posts by Vim Fuego
04-24-2009, 07:06 AM
Sonicboom
Yup I just checked and there's about a 0.8mm gap at the 9th fret.
http://i208.photobucket.com/albums/b...t/DSC03983.jpg
http://i208.photobucket.com/albums/b...t/DSC03971.jpg
Extra pics. Not sure if they're helpful though
Sonicboom
04-24-2009, 07:42 AM
Vim Fuego
Sonicboom
Yeah, difficult to tell from pictures, if the second picture is with the string pressed against the first and last frets then maybe the truss rod needs tightening... a bit...
Otherwise, shim the neck
http://www.ibanezrules.com/tech/grunge/grunge_6.htm
Jim
Vim Fuego
04-24-2009, 07:49 AM
Sonicboom
Yeah true. Nope, the strings aren't pressed in the second picture, they're open.
Guess i need to get it shimmed then.
Probably going to take it back to the store and get them to do it, i'm too afraid that i'll mess things up :/
Let's hope they do it for free
Thanks for the help everyone, I love this site
Sonicboom
04-24-2009, 08:33 PM
thesimo
Posts: 58 - iTrader: (
looks to me like you have a pretty HUGE bow in your neck so its curving towards the fretboard, making the headstock lift and thus giving you such a big action at the 12th fret even on open strings.
Get a good tech to look at it and fiddle with the truss rod etc
thesimo
Find all posts by thesimo
action
edge pro
studs
trem post
turn
what trem is on the rusty cooley
how do you turn on a tube amp
how do you turn on a tub amp
Edge studs on an Edge Pro equipped guitar?
bringer of torture
Tech: Setup, Repairs and Mods
07:28 PM
FT: Ibanez Edge Trem Studs for same...
JiMoSiTY
09:14 AM
cracks around anchor studs on edge trem
MERCYFULFATE
02:31 PM
edge trem arm, and post studs, US, where???????? :(
dollystereo
09:38 PM
04:54 PM
