Old 08-25-2009, 06:07 PM
scotteggshell  is offline
Posts: 73  -  iTrader: (0)
Edge Pro with Edge Zero Spring / Adjustment mechanism
Can anyone see a reason why this wont work.
When I remove the EZ from my guitar and put an EP in, keep the spring / adjuster setup that the EA uses instead of the standard claw? It is really nice.
Scott
Old 08-25-2009, 06:10 PM
Rich  is offline
Re: Edge Pro with Edge Zero Spring / Adjustment mechanism
If you drilled the block so the spring spacing is the same where they hook into the block i don't see any reason why it won't work, if you can squeeze the EP block into the hole in the ZPS.
Old 08-25-2009, 09:11 PM
cool ,It may also give the EP the playing tension of the EZ, which I like.
Interviewing carpenters now
edge pro, edge zero replacement
Maximum edge-pro height adjustment scotte_za Tech: Setup, Repairs and Mods 6 02-11-2007 07:05 PM
edge pro tremolo arm and arm holder adjustment tonesponge Other Ibanez Guitars (including Premiums) 6 10-12-2006 05:43 PM
Edge - spring questions. guitars'r'us Tech: Setup, Repairs and Mods 6 11-24-2005 12:59 PM
Edge Trem Spring sam_m Tech: Setup, Repairs and Mods 3 03-03-2005 11:34 AM
Can't get edge trem in adjustment - always too high, too low bduersch Tech: Setup, Repairs and Mods 4 11-19-2001 12:37 AM
