Edge Zero replacement timeframe guess
07-23-2009, 02:48 PM
scotteggshell
Posts: 73 - iTrader: (
Anyone care to guess as to when they think Ibanez is going to make a bridge to replace the Edge Zero ? That is, something that will fit the stud spacing. The Edge Zero is different from anything else.
Scott
scotteggshell
Find all posts by scotteggshell
07-23-2009, 08:14 PM
Homebake
Posts: 1,041 - iTrader: (
Re: Edge Zero replacement timeframe guess
i don't think they ever will...maybe they'll phase it out in like another 10 years or something.
Homebake
Find all posts by Homebake
07-24-2009, 05:17 PM
smooth55
Posts: 1,010 - iTrader: (
Reviews: 59
It all comes down to whether any of the patent stuff, that's been the impetus for it's evolution in the first place. If some of those laws apply, they'll change it (improvement or not remains to be seen) just enough to get around them and you'll see a replacement.
smooth55
Find all posts by smooth55
07-24-2009, 10:02 PM
Homebake
i'd like to see an improvement on the edge zero, we have enough free floating trems (edge, lo pro, edge pro etc). they need to refine the design slightly and use better quality stuff.
Homebake
07-26-2009, 07:47 AM
Cool Guy
Posts: 67 - iTrader: (
What's the problem with these trems?
I'm lazy when it comes to string changing so I tend to keep my strings until one breaks, and let me tell you, I've had the same strings on my EGEN for 7 months, and I haven't had to tune up beyond a couple of turns on the micro tuners. That tells me that
a) I haven't had a string break yet (usually get lots of string breaks down at the bridge)
b) the thing keeps the tuning pretty good.
I play that guitar 5 or 6 days a week practising/band rehearsal.
I speak as I find, but so far no complaints
All the best
Guy
Cool Guy
Find all posts by Cool Guy
07-26-2009, 08:30 AM
Homebake
Cool Guy
All the best
Guy
i run mine with the ZPS bar in. after about 3 hours or so of shredding and insane whammy bar technics (95% push downs, i don't pull up much), it's usually about...1/5th or so of a semi-tone out. i don't know how much that is in cents. either that or if all the strings but one are in tune, the one that is out will be about the same sharp or flat.
i would run it in free float mode, but you can't get the bridge level with the studs with 10's even with the spring tension at full, so you never know if it's actual level. you can't check with the knife edges like on an edge or lo pro or something. and i'm a complete noob at full free floating bridges so it keeps lifting up and i have to reset it, so i'm just gonna leave it in ZPS until i find some higher strength springs.
Homebake
07-31-2009, 09:13 AM
SilverEra
Posts: 340 - iTrader: (
Reviews: 4
Homebake
Thanks to Ibanez's exellent decision to limit the trem to 2 springs and tiny sustain block, all in exchange for a system that returns flat on pull-ups.
Please Ibanez, bring back the Edge Pro, or just bring back the Edge/Lo-Pro, you did it on the reissues, you can do it full time. You achieved perfection with those trems, trying to improve perfection is doomed to failure from the start.
SilverEra
Find all posts by SilverEra
edge bridge
edge zero issue
edge zero replacement
replacement for ibanez lo trs?
edge pro stud replacement?
how is the edge zero?
is my edge trem bar in all the way
Replacement for the edge III is on a RGT42DX?
mxr2000
Tech: Setup, Repairs and Mods
09:07 AM
Edge Zero replacement options.
scotteggshell
08:32 PM
Replacement saddle on edge pro?
Kemono
05:51 PM
Original Edge Replacement
UFORocks
12:44 AM
Lo-pro Edge tremolo - replacement for 555
kylemac
Gear and Equipment
07:41 PM
01:49 AM
