Fret Buzz need help!
03-04-2008, 02:54 PM
wandereruk05
Posts: 303 - iTrader: (
Hi all,
I've got an RG2570 (2003 model) that is a dream to play, nice low action and great sound.
I've changed the strings (at a shop) and my guitar is now riddled with buzz all over the place, the bridge is as it should be - flush to the body - and the action was as I had it, but now its buzzing like crazy all over the neck.
It didn't do this before, there was a slight buzz that I quite like, but not as bad as now that makes playing not very nice.
Any tips? Is this a
truss rod adjustment
? I dont wan't the action a mile off the neck and the nut seems to be fine, this is just after this latest string change.
Thanks everyone
wandereruk05
Find all posts by wandereruk05
03-04-2008, 03:05 PM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: Fret Buzz need help!
What kind of strings were on before and what strings are there on now? Was the gauge changed to a different gauge?
Jimmy
jb4674
Find all posts by jb4674
03-04-2008, 03:06 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
the bridge shouldn't be flush with the bdy. the knife edges of the trem should be(more of less depending on action). if the buzz is still pretty bad, loosen up the
truss rod
a bit until it relieves the buzzing, not too much, tho. if you do what can happen is that if you loosen it up too quickly, the
string tension
will increase and it will take longer for the neck to settle.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
03-04-2008, 03:10 PM
wandereruk05
hi same gauge - even the same strings!!! i dont use anything else but
Dean Markley blue steel
- haven't done for about 3 years.
I've 9-42s on this. knife edge is flush - bridge was reaching for the ceiling a while back but i sorted that with the screws in the back a while before re-string.
could it still be the truss rod? (one of the strings was off for a couple of days)
thanks
wandereruk05
03-04-2008, 03:28 PM
rty13ibz98
34
yeah, i would suspect it needs a truss
rod adjustment
. if that doesn't fix it, it needs the neck shimmed.
rich
rty13ibz98
03-04-2008, 03:39 PM
wandereruk05
at the nut or the joint of the body?
this really annoying as its been fine and now its just horrible.. truss rod slightly helped but still quite bad.. i can get it so its just the low E thats making the rattle = all the way up the neck and the then some frets quite bad from 12 onwards
wandereruk05
03-04-2008, 03:43 PM
rty13ibz98
34
under the neck joint/heel. just a small shim under the neck side bolts(not the humbucker side) should create a bigger gap under the strings, while still keeping the tension the same. just a small shim, you don't want to make it to where you have to drop the trem lower into the trem route.
rich
rty13ibz98
03-04-2008, 03:44 PM
jb4674
Reviews: 6
Raise the trem a bit and it should fix the problem.
Jimmy
jb4674
03-04-2008, 03:45 PM
wandereruk05
okie dokie - dont have the tools on me now this is such a pain - trying to sell the guitar the moment as well =/
ps thanks for the help much appreciated!
wandereruk05
dean markley
dean markley blue
dean markley blue steel
markley blue steel
neck joint
neck shim
rod adjustment
string tension
truss rod
how to fix fret board separation
how to get rid of string buzz
how to make a led fret
how to fret level
27 fret guitars?
Fret buzz at 2nd fret
aj_foes
Tech: Setup, Repairs and Mods
05:06 AM
How to elimate fret buzz completely in a guitar?
zerolight
01:06 PM
Fret Buzz from frets 11-14...?
Drew
12:02 PM
Fixing Fret Buzz - on only a single note!
mechanyx
04:15 PM
Fret Dressing How To - Not for the weak of stomach
Kyle Odom
05:06 PM
04:52 AM
