Old 12-29-2007, 11:05 PM
Force2BRW  is offline
Posts: 32  -  iTrader: (0)
g-string slipping
hey, the g-string ON MY GUITAR keeps going flat when i use the whammy bar. I have an rg1570, and i've made sure the nut and saddle weren't loose or anything. It always seems to go flat when i divebomb, and very flat if i pull up after that. what's going on? Thanks
Old 12-30-2007, 12:56 AM
jacoby66  is offline
Posts: 88  -  iTrader: (0)
Re: g-string slipping
Hmm perhaps that one spot is flat.
be careful though, if you nut is to tight you will bust ur g-string. Im pretty sure no one wants to see that happen now.
Old 12-30-2007, 03:50 AM
Distantshore  is offline
Posts: 3,671  -  iTrader: (0)
Images: 4
Old 12-30-2007, 04:06 AM
Kerem  is offline
Posts: 240  -  iTrader: (0)
Old 12-30-2007, 04:28 AM
haha no, i don't believe anyone would want that. But what do you mean that one spot may be flat? I always tune all the strings until they are all correct, lock it down and it works and stays flat fine....until i use the whammy bar. Then the g-string goes flat.
oops, i mean it stays in tune fine...until i use the whammy bar
Old 12-30-2007, 04:33 AM
jacoby66  is offline
Hmm, is the nut pad tight enough?
Old 12-30-2007, 04:39 AM
positive, i've actually tightened it so much i was worried about getting it back out. So i don't see how that could have slipped. Is there anyway to tell tho? because it does have a unwound and wound string in the same nut, so they are farthest from being similar size of all the pairs. Is it possible for it to be slipping w/ it tightened so much?
Eight string finished..... Serratus Other 7-string Guitars 62 10-05-2006 05:38 PM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 03:56 PM
Bass pickups in 7 string and 7 string single coil demo juiceofvenus Pickups & wiring 4 08-29-2003 03:54 PM
D string refuses to intonate illumina Tech: Setup, Repairs and Mods 0 08-01-2003 03:32 PM
Picking up the slack... - ...on that low string mechanyx Tech: Setup, Repairs and Mods 7 03-31-2002 02:23 AM
