Getting a guitar from Rich. Edge Zero versus Edge Pro. Which one to get?
View Poll Results
: What bridge should I get from Rich for my new quality Ibanez guitar?
Edge Zero and Maple Fretboard
28.21%
Edge Pro and Rosewood Fretboard.
71.79%
Voters:
39
. You may not vote on this poll
Page 1 of 3
08-10-2009, 03:50 AM
einarabelc5
Posts: 307 - iTrader: (
Ok guys, I need your help and wisdom over here:
Hello everyone!!
I'm in the process on getting my first real quality guitar and I do want it be something that allows me to play everything that an Ibanez is supposed to allow you to play.(I.E. play FTLOG)
I've recently read other threads on this forum about how much an
Edge Zero
bridge sucks compared to the old
Edge Pro
. Curiously 3 years ago they said the same about the Edge Pro compared to the original Edge and even more the Lo-Pro.Curiously everyone seemed to love the ball bearings on the original ZPS on the S series.
I was looking at the Prestige 3550 and I did tested the neck at Guitar Center two weekends ago. Later on I emailed Rich from Ibanez Rulez and he swiftly (Ferrari like) replied back recommending I'd just take off the ZPR system for the Edge zero to allow it to flutter. I do know that part of Rich's setup is to replace the Studs with better ones to add more stability to the bridge. So, might that bring an advantage over to the Edge-Zero system?
Still I'm doubting about getting that guitar because of that bridge, although I loved how the Maple fret board felt and that lovely buttery feeling you get from playing a 3550. Some Rosewood fretboard feel more like cardboard to me when is hot. Too porous.
So what do you guys think:
Should I sacrifice the Maple fretboard because of the Edge-zero and get an Edge-pro equipped guitar considering Rich Gold or Platinum services include an stud replacement for stability for both bridges or should I just deactivate the ZPR system from it and get the maple fretboard guitar.
Thank You in advance for all the advice!
04:04 AM
einarabelc5
Find all posts by einarabelc5
08-10-2009, 05:56 AM
coeneskens
Posts: 11 - iTrader: (
Re: Getting a guitar from Rich. Edge Zero versus Edge Pro. Which one to get?
hello, i have got an edge zero myself nd i love it, for gigs you just put je ZPR back in so it will stay in tune when you break a string and for bedroom playinf you van take it out ( takes about 10 seconds ) and then you can do cool divibombs while staying in tune perfectly!
coeneskens
Find all posts by coeneskens
08-10-2009, 06:08 AM
Posts: 19,356 - iTrader: (
The ZPS does not keep the guitar in tune if you break a string.
The EZ will do all the tricks an EP will do. It's not as sexy, not as lo profile, not as ergonomic, but it's just as functional. The arm holder torque bushing design is it's only advantage over an EP though.
08-10-2009, 06:15 AM
corpraider69
Posts: 311 - iTrader: (
How bout getting a Ibanez RG1550M that has the maple fretboard and the edge pro??
Or a RG770 or RG550 reissue (RFR or DY have maple boards) or go for a maple fretboarded original just some more options!! If you do go for the edge pro make sure you get the locking studs.
corpraider69
Find all posts by corpraider69
08-10-2009, 03:37 PM
scotteggshell
Posts: 73 - iTrader: (
I prefer the Edge Pro. I have both and play both guitars about the same amount of time. I wont say the Edge Zero Sucks, it has some very sucky features, but plays very nicely.
Here are the pros and cons I have found with the EZ
E-Z Cons:
1) Crappy fine tuners. -They are bad, bad bad.
2) Saddle design. The string contact point is behind the fine tuner pivot point of the saddle this, I believe, causes a destructive resonance that causes some notes to kill themselves when you play them. On my guitar it is the hi C#on the B string and the hi B on the Gstring. The note just plinks and dies. However this is easily fixed by wedging a piece of a pick between the saddles.
3) Sustain block is very small.
4) Great giant enormous rout in guitar
5) Working the bar changes the height of the strings much more on the EZ than the EP. You have to be careful with low action and pulling up.
EZ-Pros:
1) It feels great and plays great.
2) The Spring tension wheel is great. Saves a ton of tuning time - Have to be careful to watch trem angle tho.
3) The intonation tool works brilliantly.
4)Not a bad arm pocket. It creaks sometimes if the bushing is not quite right.
5) Very Very Stable. When setup correctly it is nearly impossible to knock out of tune.
The only real problem I have with the Edge Pros is that it feels a bit light or non linear or something
I am getting rid of the edge zero.
Scott
scotteggshell
Find all posts by scotteggshell
08-10-2009, 04:57 PM
SilverEra
Posts: 340 - iTrader: (
Reviews: 4
Edge Pro on a rosewood fretboard.
The Edge Zero does have
some
good points, but no where near enough to balance out the cons.
To respond to the last posts pros,
scotteggshell
EZ-Pros:
True, but no where near on par with the EP/Edge/Lo-Pro. It feels alot stiffer, and I find that it doesn't flutter aswell either (doesn't flutter AT ALL with the ZPS bar in.) It's looks don't help either, tbh. The screw-in intonation tool right on the face of it is just plain rediculous.
scotteggshell
Yep.
scotteggshell
Yes, but the amount of times I actually need to intonate is so small, I can really live with out it. Again, that screw-in tool on the face of the trem is just plain hideous, the designer of which should have a finger wagged at him. . . then shot.
It just feels "gimmickey" to me, rather than a genuine design improvement.
scotteggshell
The arm pocket is indeed very good. I don't think the brushing is the cause of the creaking, I've adjusted mine to no end and it still makes noise, even without a brushing in there. The only solution I've found is some WD40 oil, stops it creaking for a few months and then starts up again. I've got no idea what-so-ever what's causing it...
scotteggshell
It stays in tune, but so does the edge pro. One thing to mention though, the Edge Zero DOES, I repeat, DOES, come with locking studs. But if you go with the
's Edge Pro mod for a bit extra, that doesn't make a difference anyway...
SilverEra
Find all posts by SilverEra
08-11-2009, 01:34 PM
scotteggshell
SilverEra
I'm glad you heard that quiet one too. I couldn't locate or even really reproduce it faithfully either. But if the bushing is not aligned properly you do get a different, rather loud, pinging like a bad tuner or nut on a non locking guitar.
scotteggshell
08-11-2009, 02:58 PM
einarabelc5
What about the S series, what are the Pros and Cons of the Original ZR trem with the ball bearings compared to the Knife Edged -Edge-Z?
03:22 PM
einarabelc5
08-11-2009, 06:57 PM
SilverEra
Reviews: 4
einarabelc5
They're essensially the same, exept the EZ flutters better.
SilverEra
08-11-2009, 07:03 PM
einarabelc5
SilverEra
Thanks!!!
Haha, and here I was wondering if I should get the S. So Knives edges still kill ball bearings?
Is the sustain block of the Edge Z as small as the ZR in the S? As it is shown on this video:
http://www.youtube.com/watch?v=gOZtQT5TPYw
einarabelc5
08-11-2009, 07:19 PM
einarabelc5
scotteggshell
Check this video out:
Towards the end he describes what might be the problem. If I were you I'd check that out. Maybe Rich has a solution for that.
einarabelc5
08-11-2009, 08:40 PM
einarabelc5
einarabelc5
Forget it, The Zero ueses the Edge Arm holding system as it does the ZR 2.
Oh and BTW, according to this site :
http://lawl.net/gtr/trems
the Zero is built in China, not Japan.
Anyone can confirm that?
einarabelc5
08-12-2009, 05:25 PM
scotteggshell
einarabelc5
What about the S series?
Try one , I almost ordered one, then happened to be travelling in the US and tried one. They feel funny to me. Very light with a kinda chunky seeming neck. I got a RG1570 instead and I think it is the bees knees.
scotteggshell
08-12-2009, 05:38 PM
SilverEra
Reviews: 4
einarabelc5
Confirmed.
SilverEra
08-12-2009, 06:10 PM
einarabelc5
scotteggshell
That's what all the other guitarists say about the S. The ball bearings give it stability but the trem doesn't moves as smoothly as with knife edges. The 1570 was the very first RG I ever mouthwatered and the first
Prestige
I ever tired (I have an story regarding that time). I'm also considering the 1550 with its Maple neck. The only prob are the PUPS...After trying the 3550, there's no comparison between Dimarzio and Ibanez.
einarabelc5
Page 1 of 3
edge pro
edge zero
prestige
rich
will edge zero pro fit edge 3 route?
how do i fix a synsonics guitar?
how to set up a edge 3?
Edge studs on an Edge Pro equipped guitar?
bringer of torture
Tech: Setup, Repairs and Mods
07:28 PM
hey Rich? can ya put an edge ZR on a Xiphos?
lamusician
11:36 PM
IBZ LO-PRO EDGE versus the newer bridge
elpingua
07:13 AM
Lo-Pro Edge in my B.C. Rich?
MetalWarrior
03:24 AM
Old Edge versus New Edge
thebigugly
12:51 AM
07:53 PM
