Having trouble with tuning
04-11-2006, 06:53 PM
offie
Posts: 19 - iTrader: (
Hey there
Just got a new j custom 8270 onyx black. i cant get it to stay in tune!! its always going flat and i have no idea how to use this bridge properly. Im at the stage atm where i just want to slap a chunka wood under it and have done.
tighten the fine tuning screws on the bridge, and then check all the strings. more have gone flat. retune and run out of thread eventually. undo nut locks, repeat process. Gah and then i notice the bridge has been pulled miles into the air so i undo the nut locks again and lower it and now its all out of tune again.
any help at all? I love everything about the jcustom except i cant play it
offie
Find all posts by offie
04-11-2006, 08:20 PM
ibanez2005
Posts: 910 - iTrader: (
Re: Having trouble with tuning
You gotta tighten the springs up in the trem cavity more then, thats the only problem here i can see.
Also, set the fine tuners to around center, tune with the
tuning pegs
, once youve done that, lock the nuts down and fine tune it from there, should be ok.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
04-11-2006, 08:29 PM
norvan
Posts: 80 - iTrader: (
new strings i'd say. Yeah, getting it to zero point and all strings in tune is harder than rocket science.
norvan
Find all posts by norvan
04-11-2006, 08:38 PM
S-man
Posts: 1,757 - iTrader: (
Stretch your strings, if new.
It is the springs and strings, you need to balance the
string tension
to the spring tension. In the cavity, on the back of the guitar, behind the plate, there are screws to adjust the spring tension.
Those springs need to be adjusted to balance the string tension.
Either look here (jemsite.com) under setup or at ibanezrules.com.
That always happens at first, welcome to the club.
Don't give up.
S-man
Find all posts by S-man
04-12-2006, 01:01 AM
lyconxero
Posts: 1,469 - iTrader: (
If the guitar has the factory strings on then I would suggest cutting them off and putting on a fresh pair. I don't know why, but I could never get my guitar with the factory strings to stay in tune like I wanted but after I changed the strings the first time I didn't have any more problems. So I would say start anew, stretch, stretch, stretch some more, take a breather, stretch, stretch, REALLY stretch, and then set the trem level and get the guitar in tune. After that, lock the nut, adjust with the fine tuners and see if you still have the same problems.
lyconxero
Find all posts by lyconxero
04-12-2006, 03:23 AM
GTR-MAN
Posts: 1,056 - iTrader: (
Vists the tech section of this site or click on the ibanezrules banner at the top of the page and check out the tech section there.
GTR-MAN
Find all posts by GTR-MAN
04-12-2006, 05:20 AM
offie
I'm scared about adjusting the spring on the back... is it safe? will i break it?
Also im nervous about replacing the strings. i mean i know i need to undo the screws on the trem itself but how do i get the balls out?
Yes these are factory strings. Why would the springs make a difference? Is it to do with the see-saw effect? If so, could someone explain how the springs tie in with this?
Cheers!!
Offie
offie
04-12-2006, 05:25 AM
Bezial
Posts: 540 - iTrader: (
slacken of the locks on the trem enough and the balls will come out. adjusting the springs at the back is no hassle either just tighten them to bring the trem down or visa versa to go up(hope i got that the right way round ) the strings will make a differance as they may have been on there for a year (2005 model) and could be shot completly , when you change them depending what gauge you are going to have to adjust the back springs anyway (i like 9-46 and they come with 9-42 )
hey hope you get it sorted as i have the 8270 and its a lovly guitar
Bezial
Find all posts by Bezial
04-12-2006, 06:15 AM
AleTheNervo
Posts: 459 - iTrader: (
you only need some practice and be patient
AleTheNervo
Visit AleTheNervo's homepage!
Find all posts by AleTheNervo
04-12-2006, 06:50 AM
eviltwin
Posts: 1,629 - iTrader: (
In addition to the previous remarks:
Don't take off all of the strings at once, only change one at the time.
Also make sure that (supposing your guitar came with 009s) you put 009s on it.
If it came with 009-042 *don't* put 010s or hybrids (009-046s) on it until you know how to compensate for this in your set-up!
Keep the ball ends on. Edge pro allows you to load them into the trem, but I prefer to have the balls at the headstock end. See 6th post from top:
http://www.jemsite.com/forums/showth...ight=ball+ends
SSV has been doing this at least since 1991:
http://www.ibanezrules.com/catalogs/us/1992/uv.jpg
The trem angle should be such that the knife edge is parallel and coincident with the top of the body. Assuming the neck, nut and intonation are set-up properly, if the knife edge is not coincident the tremposts may need adjusting. (best to check this using the bar to hold the trem in a parallel position, if it isn't parallel already)
Tuning guide (use a tuner!):
Unlock nut.
Tune completely using the pegs, keep fine tuners centered (so you can still go up or down).
I usually tune low-E to high-E then back and again if necessary, some prefer to go low-E to hi, then low to hi again.
Check trem angle & height.
If angled backwards/forwards, turn
trem springs
by 1/4 to 1/2 turn
And retune completely using the pegs
(Check trem angle again repeat loop^^)
Lock nut.
Finalize tuning using the fine tuners. (locking the nut will throw the tuning out by a hair)
Done
(BTW I don't believe in stretching, if the nut and trem are properly fastened there is *no* stretch. Just pull the new string hard to make sure it's properly locked on both sides)
If any tuning instability remains, this is most likely due to some other part not being fastened correctly, IE neck bolts,
locking nut
, trem posts (not on Edge Pro)
eviltwin
Find all posts by eviltwin
04-12-2006, 08:48 AM
fettouhi
Posts: 9,937 - iTrader: (
GTR-MAN
+1
Regards
André
fettouhi
Find all posts by fettouhi
04-12-2006, 08:57 AM
markg5150
Posts: 2,361 - iTrader: (
Ibanezrules tech section is all you need to know
markg5150
Find all posts by markg5150
04-15-2006, 05:16 AM
offie
Went into my
local guitar shop
- they recommended I stick 2 extra springs in the back of the guitar. There are 2 extra holes for springs, so i'm presuming this is possible.
Any ideas where I can find the springs?
offie
04-15-2006, 09:57 AM
S-man
offie
Went into my local
guitar shop
There should be 3 spring there already. 5 springs?! Put some .009
guage strings
on it and adjust from there. You need to adjust the springs that are there, so that the trem ,with the guitar in tune, is parallel with the body.
Don't listen to the guitar shop dude.
Don't be scared to adjust the springs, it's just 2 philips head screws. Tightening the screws will have a similar affect as adding a spring, you will be increasing spring tension. Now stop being a wus, break out the philips and adjust that thing
READ the Tech section here and at Ibanezrules.com.
S-man
guage strings
guitar shop
local guitar shop
lock nut
locking nut
neck bolts
string tension
trem springs
tuning pegs
how to do drop f tuning
when did tom anderson introduce buzz feiten tuning system
string gauge for b tuning?
mushroomhead tuning?
what tuning is this beadgb
Tuning Down and String Guages
slugman
Tech: Setup, Repairs and Mods
06:08 PM
Help with tuning nightmare!! RG2820
bhuether
05:08 PM
Tuning probs
Zeroleet
07:26 PM
"acceptable" tuning stability
jeffrg270
10:12 PM
Tuning Trems and Trouble - The Triple T Turmoil
Two hands31
09:15 AM
12:25 PM
