Old 12-15-2006, 04:47 AM
Helldogg  is offline
Posts: 24  -  iTrader: (0)
I'm starting to really hate Ibanez
Ok some of you may remember I got a RG1570 a while back with buzzing problems. Well I returned it their "tech" said it had a twisted neck (I told them that, but its ok they need to prove it).
So anyway they get me another one, string it up and guess what, it frets out a buzzes on the low E only. So I notice the neck joint is bit high like it was shimmed. So I think maybe its shimmed to high, take the neck off and guess what?
The neck is stamped RG2550! I'm guessing this is the wrong neck, maybe I'm wrong, but this is getting silly.
So are the presteige guitars really all this bad? I mean 2 guitars with problems? How common is this?
Old 12-15-2006, 04:56 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Re: I'm starting to really hate Ibanez
Never had problem with the prestige and gios over here, I guess the tech over at your area are just plain mad
Old 12-15-2006, 05:02 AM
Ayrton  is offline
The 2550 and the 1570 get the same neck.
I have never purchased a new guitar that did not need a pro set up, so you may just need a little tweaking. Now a twisted neck is another story entirely.
I highly recommend returning it and getting a new 2550 from Ibanez Rules. Not only will you get a hand picked guitar, but the full monty set up from Rich Harris.
Old 12-15-2006, 01:01 PM
P.D.U.-OTIO  is offline
Posts: 166  -  iTrader: (5)
All Ibanez guitars, in fact, I don't many guitars that still don't need a fretdress, a shim, a pro set up can't be done without these being done, you may get a good setup out of a stock out of the box guitar, but it will not be as it would or you would really want unless these things are done first.
That's all I can suggest, find a good tech, that know's and practices these procedures, with a proper fretdress and setup, that is the only way to get the best setup without buzzing.
Good luck,
Andres
Old 12-15-2006, 02:49 PM
buddroyce  is offline
Quite honestly.. I'm not trying to be a complete snob here, but I personally have found most Prestiges to be on the same level as most production guitars and personally only buy the J-Custom line nowadays. Like P.D.U.-OTIO said, pretty much all guitars need a good fretdress even if it's new.
Mind you, is it a LOT of buzz or just a minor amount of buzz?? And do you only hear it on an open string without palm muting? Players like Slash and Joe Satriani have their guitars set up to buzz just a little bit when not palm muted, but sound fine when you do palm mute. (how often do you play without palm muting anyways?). Have you considered just raising the action on the low side just a notch? Giving a 5-10degree turn helps a lot sometimes.
Old 12-15-2006, 03:05 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Smile
If the first guitar you bought had problems, why didn't you just return it and buy one from Rich?
Jimmy
Old 12-15-2006, 04:20 PM
Unknown Doodl3.2  is offline
Posts: 279  -  iTrader: (1)
who cares if its stamped 2550? its the same neck...
Old 12-16-2006, 12:01 PM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
+1
Regards
André
Old 12-16-2006, 12:43 PM
Tom Gilroy  is offline
Posts: 1,747  -  iTrader: (0)
A bit of buzz has never bothered me unless it comes out of the amp.
Old 12-16-2006, 12:53 PM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
If you know this little about ibanez Im not entirely convinced you now how to set one up or if the buzz youre experiencing is just the normal low action buzz that we all get.
ibanez guitars, joe satriani, neck joint, palm mute, palm muting
What I Hate About Ibanez Thrash J-Custom, USA Custom & Prestige Ibanez Guitars 318 Yesterday 03:56 AM
how many Ibanez guitars do you own? spacenuke Other Ibanez Guitars (including Premiums) 1534 01-22-2012 05:08 PM
Ibanez & Vai timeline of events - working together jemsite Archived Topics and Common Questions - GO HERE FIRST 16 04-02-2009 03:38 PM
Enquiring about 2nd guitars GuitAust Vendors, Auction & Reseller Talk 27 09-24-2006 10:40 AM
Ibanez catalogs - call for scans jemsite Other Ibanez Guitars (including Premiums) 82 03-27-2006 11:38 PM
