Old 07-14-2009, 11:40 AM
JRBain  is offline
Posts: 21  -  iTrader: (0)
Exclamation
Installing a fourth trem spring... Help please?
Hey there chaps, question as above. I've recently put 11s on my RG1570, but as expected, need an additional spring to bring it up to standard tuning. How should I go about doing this exactly? Either explanations or directions to a guide would be fine. Don't worry about being patronising; when it comes to guitar techery, I'm quite the novice.
Cheers! :thu:
Old 07-14-2009, 12:37 PM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Re: Installing a fourth trem spring... Help please?
not a deal, just attach the fourth spring in one of the spring-block screw holes, like so:
if that's what you needed to know
Old 07-14-2009, 01:28 PM
SilverEra  is offline
Posts: 340  -  iTrader: (0)
Reviews: 4
Just out of curiosity, what's the advandage that four springs have over three. Never actually asked :P
Old 07-14-2009, 02:06 PM
AxeHappy  is offline
Posts: 678  -  iTrader: (2)
He's using 11 gauge strings so he can't get the bridge to set level with only 3 springs.
Old 07-15-2009, 04:33 AM
brianxtr  is offline
Posts: 1,642  -  iTrader: (8)
there are special springs for 7 strings.those are stiffer.maybe you can try that too?
its a gues but i think it works..nuno's solution is okey too
Old 07-15-2009, 05:27 AM
JRBain  is offline
Thanks for that. When my spring arrives I'll give it a go. :thu:
Not heard of those, but thanks. If I were buying a new spring set, I'd consider it, certainly.
Old 07-15-2009, 08:04 AM
GazTop  is offline
Posts: 172  -  iTrader: (2)
Interestingly why wouldn't you have the outer 4 pegs with springs and the inner peg without a spring?
That way it would be balanced as opposed to your version.
Edit- i see the bar holding the springs in uses that specific hole so i'm guess thats why. However i don't even use the spring retainer bar and my srpings never pop out so you could give that a try if you feel so inclined.
Old 07-18-2009, 02:19 AM
newbieguitarmaker  is online
Posts: 4,030  -  iTrader: (5)
Images: 1
My springs never stay in on my 7 without the retainer so maybe that is his problem Gaz
Old 07-18-2009, 05:52 AM
GazTop  is offline
Yeh that sounds about right then.
Interestingly i just retuned my RG3120 to C standard and installed 4 springs without the retainer bar and it works fine.
Old 07-20-2009, 05:04 AM
nuno  is offline
it has to do with the neck/body/trem geometry and how you trem is setup to pull back. many times you can't go without the spring-retainer.
11-54, edge pro, ibanez rg1570
installing a trem kelmaur Tech: Setup, Repairs and Mods 7 08-15-2007 02:43 PM
WTB trem spring claw. nightfiend14 Classified Ads: Guitars and Gear 4 07-28-2006 02:56 AM
Edge Trem Spring sam_m Tech: Setup, Repairs and Mods 3 03-03-2005 11:34 AM
Trem spring damping Random Man Tech: Setup, Repairs and Mods 9 07-24-2004 10:19 PM
USRG30 trem spring setup gkelm Tech: Setup, Repairs and Mods 0 11-07-2002 02:36 AM
