J-Custom sound question
05-30-2007, 06:05 PM
Alexeh
Posts: 100 - iTrader: (
The mahogany/flame combo is turning me off! I think that would sound too warm, so I'd like to ask for thoughts on this?
Alexeh
Find all posts by Alexeh
05-30-2007, 06:29 PM
eelblack2
Posts: 865 - iTrader: (
Re: J-Custom sound question
Probably has as much or more to do with your
pickup selection
. I have a Mahogany/Quilt Maple JC7 and it has great snap with PAF7s. I could imagine with an Evo 7 or X2N7 it would take your head off with high end.
eelblack2
Find all posts by eelblack2
05-30-2007, 09:11 PM
zEr0
Posts: 1,223 - iTrader: (
I'm with you, mahogany is not my body wood either. Even with a maple top it just sounds too muffled... And I hate bright pickups so that's not an option. BASSWOOD ALL THE WAY!!!
zEr0
Find all posts by zEr0
05-31-2007, 12:03 AM
Alexeh
I have an alder, basswood and mahogany guitar but the basswood does seem just right! Basswood ftw!
Alexeh
05-31-2007, 12:18 AM
Ferrous Lepidoptera
Posts: 472 - iTrader: (
eelblack2
Probably has as much or more to do with your pickup selection. I have a Mahogany/Quilt Maple JC7 and it has great snap with PAF7s. I could imagine with an Evo 7 or X2N7 it would take your head off with high end.
To some extent. I have a RG3120 with mahogany/flame maple top and an RG8670 with mahogany/flame top, both with a ToneZone in the bridge, yet they sound remarkably different. These guitars are seemingly very similar, but so different in sound that I've come to the conclusion that if you want to know what a guitar is going to sound like, you've just got to play it. There is no substitute. You can speculate based on the specs, but each guitar has it's own quirky sound, however meticulously their makers try to make different instances of a given model identical. I own two instances of an RG520QS which sound different from each other, for instance.
Ferrous Lepidoptera
Find all posts by Ferrous Lepidoptera
05-31-2007, 03:49 AM
GAZ
Posts: 442 - iTrader: (
Ferrous Lepidoptera
The variations in pup height, action and freshness of the strings makes a difference between the sound of 'identical' guitars. Your 8670 has maple
neck binding
and an
ebony board
which will sound brighter than the rosewood on the 3120.
GAZ
Find all posts by GAZ
05-31-2007, 04:03 AM
GAZ
J Customs muffled ??? They have (usually) bolt on
maple necks
and a
Floyd Rose
type trem which increase top end and lose bottom end respectively. Both of mine with TZ pups can strip paint from the back wall if required, I rarely have the treble much above 4.5 on my Recto and the presence is on 1 ! Your amp set up is more important than your guitar in your overall sound. Invest in a quality valve/tube amp before you spend truck loads on guitars !
GAZ
05-31-2007, 10:42 AM
Alexeh
Well not muffled really, but on the bassy side obviously since it's a piece of mahogany.
Alexeh
05-31-2007, 01:41 PM
eelblack2
As Gaz said, setup can make a huge impact on the overall sound of otherwise identical guitars. I have no problem whatsoever making a HRG4-BX bark on the high end. Most of my guitars have different setups to accomodate various aspects of what I want it to play and sound like. For me, a wide assortment of pickups further broaden that range of tones.
eelblack2
06-01-2007, 12:42 AM
mi2tom
Posts: 7,522 - iTrader: (
zEr0
+1!
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
ebony board
flame maple
floyd rose
maple neck
maple necks
neck binding
pickup selection
tube amp
how to achieve brown sound
How to get EVH Brown sound
where is sims custom shop address
where is the ibanez japan custom shop
how to get the "korn" sound
Transcript of Aussie Vai I'view (didnt know where to put it)
TheOrangeChannel
12:52 AM
blaze custom vs custom 7 (also called NEW 7)
ibanez7addict
Other 7-string Guitars
11:04 PM
Question about Vai sound.
Nilsefix
Gear and Equipment
32
07-14-2004
11:21 AM
A simple question concerning the sound of RG3120
particlestorm
04:48 AM
Evo7 vs. Blaze Custom? - My last question, I swear!
bduersch
Tech: Setup, Repairs and Mods
03:04 AM
08:18 AM
