Old 07-10-2008, 11:30 PM
AKMG  is offline
Posts: 352  -  iTrader: (0)
JEM Neck and Prestige Neck
Does the RG3120 have the same neck as the JEM? Played a JEM today and it felt a lot faster and easier to handle. How much does a JEM neck run for and could I get a custom built one?
Old 07-11-2008, 12:04 AM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Re: JEM Neck and Prestige Neck
Probably $700-$900 for an Ibanez Jem neck, do a search for custom Jem necks there's been a ton of talk about them.
Old 07-11-2008, 01:19 AM
AKMG  is offline
Jesus Christ! That's probably how much my current guitar is worth right now...
I'm not after a JEM neck exactly, but a neck that has the exact same specifications as the JEM (tolerance @ +- 0.0001").
I figured a neck would only be $200 max :/
Old 07-11-2008, 02:05 AM
AustinPlaysGuitar  is offline
Posts: 99  -  iTrader: (0)
yeah, i got my neck from the bay for 600, you would be extremely lucky to find one for 200 and if you do, its a faux most likely.
Old 07-11-2008, 03:16 AM
Ayrton  is offline
You can't even get a nice Prestige neck for $200, let alone a JEM neck.
For what it is worth, the JEM necks are a tad thicker than the neck you played.
Old 07-11-2008, 10:08 AM
bulletbass man  is offline
Posts: 121  -  iTrader: (0)
About one mm thicker.
Click some of the links at the top of the site. Some of them build necks (though not necessarily to Jem specs. You'd have to contact them
Old 07-12-2008, 12:11 PM
Takin' a Ride  is offline
Posts: 1,760  -  iTrader: (27)
The 3120 has the wizard neck profile, which is very thin and flat across the back. The JEM necks are a bit thicker and rounder.
On their print ads way back in the day, Ibanez used to show cross sections of the wizard, JEM and whatever neck it is they used on the S-series. It was extremely clear from that picture if you could dig one up.
EDIT: Success!
Old 07-12-2008, 06:16 PM
brianxtr  is offline
Posts: 1,642  -  iTrader: (8)
great to see! nice
Old 07-13-2008, 08:01 PM
mike570  is offline
Posts: 2,221  -  iTrader: (0)
Reviews: 18
IMO Wizard 2 feels closer to a Jem neck than a Prestige. They're about the same but W2 has a slightly shorter radius.
wizard neck profile
Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck? Duck_man J-Custom, USA Custom & Prestige Ibanez Guitars 10 08-20-2007 12:01 AM
Jem Neck Vs. Prestige shogun JEM and Universe Guitars 10 05-14-2007 08:40 PM
What is the difference between a Jem Prestige neck and a normal Prestige neck? evolusean Gear and Equipment 1 05-05-2007 05:19 PM
Prestige Neck Ironjose J-Custom, USA Custom & Prestige Ibanez Guitars 11 05-17-2006 11:04 PM
Prestige neck vs. JPM100 neck? leishan J-Custom, USA Custom & Prestige Ibanez Guitars 19 01-07-2003 07:46 AM
