JEM Neck and Prestige Neck - Jemsite
post #1 of 9 (permalink) Old 07-10-2008, 10:30 PM Thread Starter
Does the RG3120 have the same neck as the JEM? Played a JEM today and it felt a lot faster and easier to handle. How much does a JEM neck run for and could I get a custom built one?
AKMG is offline
post #2 of 9 (permalink) Old 07-10-2008, 11:04 PM
elcid's Avatar
Re: JEM Neck and Prestige Neck
Probably $700-$900 for an Ibanez Jem neck, do a search for custom Jem necks there's been a ton of talk about them.
elcid is offline
post #3 of 9 (permalink) Old 07-11-2008, 12:19 AM Thread Starter
Jesus Christ! That's probably how much my current guitar is worth right now...
I'm not after a JEM neck exactly, but a neck that has the exact same specifications as the JEM (tolerance @ +- 0.0001").
I figured a neck would only be $200 max :/
AKMG is offline
post #4 of 9 (permalink) Old 07-11-2008, 01:05 AM
yeah, i got my neck from the bay for 600, you would be extremely lucky to find one for 200 and if you do, its a faux most likely.
AustinPlaysGuitar is offline
post #5 of 9 (permalink) Old 07-11-2008, 02:16 AM
Ayrton's Avatar
You can't even get a nice Prestige neck for $200, let alone a JEM neck.
For what it is worth, the JEM necks are a tad thicker than the neck you played.
Ayrton is offline
post #6 of 9 (permalink) Old 07-11-2008, 09:08 AM
About one mm thicker.
Click some of the links at the top of the site. Some of them build necks (though not necessarily to Jem specs. You'd have to contact them
bulletbass man is offline
post #7 of 9 (permalink) Old 07-12-2008, 11:11 AM
The 3120 has the wizard neck profile, which is very thin and flat across the back. The JEM necks are a bit thicker and rounder.
On their print ads way back in the day, Ibanez used to show cross sections of the wizard, JEM and whatever neck it is they used on the S-series. It was extremely clear from that picture if you could dig one up.
EDIT: Success!
Takin' a Ride is offline
post #8 of 9 (permalink) Old 07-12-2008, 05:16 PM
great to see! nice
brianxtr is offline
post #9 of 9 (permalink) Old 07-13-2008, 07:01 PM
Reviews: 21
IMO Wizard 2 feels closer to a Jem neck than a Prestige. They're about the same but W2 has a slightly shorter radius.
mike570 is offline
wizard neck profile
Human Verification
Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck? Duck_man J-Custom, USA Custom & Prestige Ibanez Guitars 10 08-19-2007 11:01 PM
Jem Neck Vs. Prestige shogun JEM and Universe Guitars 10 05-14-2007 07:40 PM
What is the difference between a Jem Prestige neck and a normal Prestige neck? evolusean Gear and Equipment 1 05-05-2007 04:19 PM
Prestige Neck Ironjose J-Custom, USA Custom & Prestige Ibanez Guitars 11 05-17-2006 10:04 PM
Prestige neck vs. JPM100 neck? leishan J-Custom, USA Custom & Prestige Ibanez Guitars 19 01-07-2003 06:46 AM
