Neck help?
09-09-2005, 12:49 AM
Thrash
Posts: 679 - iTrader: (
Neck help?
Will a new Prestiege neck replace an old wizard I on a 560 or 550?
Thrash
Find all posts by Thrash
09-09-2005, 09:45 AM
buddroyce
Posts: 1,914 - iTrader: (
Re: Neck help?
Any
AANJ neck
should be able to replace any other AANJ neck. If the 560/550 that you have is an older style
neck joint
then you're S.O.L.
buddroyce
Visit buddroyce's homepage!
Find all posts by buddroyce
aanj neck
neck joint
parker are they neck thru
how can i tell thin or standard neck prs
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
The Super Wizard Neck ??? - is this the neck on my USA Custo
Jimi D
12:02 AM
What is the best way to drill neck holes in new body.....
SilverSurfer2
Tech: Setup, Repairs and Mods
06:41 PM
A New Neck - How long does a neck take to settle?
7 Dying Trees
11:06 AM
RG270 neck versus 570 neck? - how close are the wizard and w
BZ Beetle
05:59 PM
Changing Vine inlay colors - things that make you go hmmmmmm
tomizm
34
04-13-2001
03:14 PM
02:34 PM
