Old 07-08-2008, 12:26 AM
Force2BRW  is offline
Posts: 32  -  iTrader: (0)
New Pickup too high...please help
Hi, i have been reading that many rg 1570s are not able to accept larger pickups (EVO, Invader, etc.) Unfortunately, i have one that won't accept a Seymour Duncan SH-8 Invader pickup. I was just wondering what i can do to fix this (most likely routing), where i can get it done, and how much it would cost me. (I don't really want to just settle for another pickup, as i really wanted this particular one)
Also, is it possible to modify the pickup itself to accomidate the guitar? Example: Shoren the metal legs it stands on? I'll give you rough picture of what i mean...
(ignore dotted lines, i needed a placeholder)
-------________________
-------|--------------------| <-----Pickup
-------|_______________|
----__|--------------------|__ <-------Metal that comes down to screw into body
...try to change this ^ to below...
----__|_______________|__
You get the idea...shorten the legs. Or is this a bad idea? Any help is appreciated, and i thank you in advance.
Old 07-08-2008, 12:30 AM
elcid  is offline
Posts: 8,720  -  iTrader: (12)
Re: New Pickup too high...please help
Any tech can do it, you'd have to ask him what it would cost though.
Im sure a quick search would give you some ideas as to how other people have hendled this.
Old 07-08-2008, 12:35 AM
Rich  is online
For a Steve's Specials you have to counter-rout the wood under the feet just enough to allow ample string clearance over the pickup. You can do it with a Dremel.
Old 07-08-2008, 01:29 AM
can you use a power drill? or does it have to be a dremel? sorry for so many q's, but....will i need to redo the screws? will it mess up guitar for other pups? and does it take a lot of skill? Whew....thanks to whoever doesn't hate me for all the q's...
Old 07-08-2008, 02:35 AM
Rich  is online
You're not drilling a hole, you're routing a flat spot for the feet, although if you must I'm sure even a series of holes would do the job, if you don't mind doing a hack job.
Old 07-08-2008, 07:07 AM
i know i'm not drilling a hole, but if you change the head of a power drill it can do other things besides just drill holes. and i was just wondering if i would have to drill the holes for the pup deeper.
p.s. has anyone done this? if so, did you get it done somewhere or did you do it yourself? I was just looking for a ballpark estimate...
Also, are 1570 pups adjustable after you put them in? or do you have to actually take them out and put them in again to adjust the pup height? the stock ones didn't really get higher when i turned the screw on the sides, and it seems like once you get it in, you cant change height without taking them out and trying again. thanks
Old 07-08-2008, 12:31 PM
HeavyMetal4Ever  is offline
Posts: 1,172  -  iTrader: (0)
I didn't have to rout my 1570, but i've routed another guitar with a cheap Dremmel copy. Good results are easy with common sense and a bit of patience. Good luck.
Rock on!
Old 07-08-2008, 09:47 PM
Ibanez-Mag  is offline
Posts: 520  -  iTrader: (0)
A kit like this does the job really easy (it is really ahrd to screw it up).
Use the small cutter tool.
And it is a good tool to have for a lot of other guitar work too (polish frets and so on).
/magnus
Old 07-09-2008, 07:31 AM
that looks like a pretty nice kit...what's it called do you know? or is it just a basic kit? I'm going to stop by Home Depot soon and talk to some ppl there, so they should be able to answer some questions. thanks for everyones help! It doesn't seem like routing the guitar is that hard if you have an idea what your doing.
quick question, i just route the two sides where the pup screws in right? not the entire cut-out.
Old 07-09-2008, 07:51 AM
I don't know what that specific model is called, but they have loads of different price versions in every "home tool" shop.
Take as much as you need.
I hade to deepen the whole area under the pickup (not where the feet’s go down) on the ones I had to change. Especially when installing a EVO 7 in a RG1527.
I think I have had to do routing on 3 out of 25-30 RG guitars.
Buy some electronic shielding paint at the same time to close the open wood (but any dark color will do, and also make it look better).
Good luck, but it should be now problem unless you have all your fingers in a cluster in the middle of your hand (putting some pressure here) :-)
/Magnus
Old 07-09-2008, 04:50 PM
rub_800  is offline
Posts: 93  -  iTrader: (0)
I changed the pickups of my 1570 and put an evo. The tech found this problem with my guitar and he shortened the legs of the pickup somehow (by bendig them)... I don't know how he did it but it worked.. so I think it possible..
1570 routing pickup high
Bridge pickup too high -- metal shim thing? allanw Pickups & wiring 1 05-01-2007 11:45 PM
Pickup high and tone? Azrael Pickups & wiring 5 01-16-2005 10:32 AM
Strange JPM reaction - trem too high? pups too high? julio Tech: Setup, Repairs and Mods 7 08-07-2001 07:39 PM
Pickup is too tall for cavity - direct mounted pickup tomizm Tech: Setup, Repairs and Mods 8 05-09-2001 06:22 PM
