Re: one more pickup question for RGA's... covered pickups fit the routing?
Those pickups should definitely fit as I've seen an RGA121 with BareKnuckle PU sell on bay-E. So, unless that seller altered the guitar without mentioning it they must have fit right in.
With your friend's guitar do you mean he had to grind down where the pickups mount in the guitar? I know when I put my DiMarzio X2N into my RGA I had to do that because the pickup is fairly tall (the backing plate is the same size as the stock pickups, though) and when screwed down completely flatly to the guitar it was too high. A little dremel tooling later it was low enough. Wasn't hard to do.
