Opinions on RG2610E
04-17-2008, 04:47 PM
jwoods986
Posts: 378 - iTrader: (
Opinions on RG2610E
I was in a store yesterday and picked up a 2610 to play. I was playing it for a few minutes, then looked at the tag - let's just say, it's on clearance! Obviously, it's a left-over '07 but I looked it over, expecting it to be beat to hell, but it's not. It's like new, no dings, chips, gouges, etc. The neck felt really nice but I was on lunch, so I didn't have time to plug it in. What's the general opinion here on these? (the most obvious short-coming being the one-hum configuration).
jwoods986
Find all posts by jwoods986
04-17-2008, 05:04 PM
albee1952
Posts: 784 - iTrader: (
Re: Opinions on RG2610E
Very nice guitar with very limited sounds(you noticed). Sort of a one trick pony unless you do like I did and add more pickups
albee1952
Find all posts by albee1952
04-17-2008, 05:19 PM
jwoods986
That's nice, but I think I would just pick up a 2550 before doing all that. (I'm not a handy man -lol)
jwoods986
04-18-2008, 02:17 AM
Ibateur
Posts: 2,947 - iTrader: (
nice though intonation looks fishy.
Ibateur
Find all posts by Ibateur
04-18-2008, 02:35 AM
Petie
Posts: 2,877 - iTrader: (
I like the RG2610E but if I had one I'd install a push-
pull coil tap
and change the pickup to a
Seymour Duncan
Parallel Axis Trembucker.
I don't think the single pickup format is a shortcoming. It was good enough for EVH, as well as anyone who ever played a Fender Esquire (which had a tone control and a tone switch too, but who ever used them?) or a Les Paul Special.
Petie
Visit Petie's homepage!
Find all posts by Petie
04-19-2008, 01:19 PM
kool98769
Posts: 37 - iTrader: (
Petie
I like the RG2610E but if I had one I'd install a push-pull coil tap and change the pickup to a Seymour Duncan Parallel Axis Trembucker.
I've found that
bridge pickups
generally sound great for rhythm...not so much for soloing.
Hence why we have neck pickups!
Not to mention, the bridge is natrually bright. So if theres a section that you want to be a little more warm, you can always switch to the
neck pickup
kool98769
Find all posts by kool98769
04-19-2008, 02:00 PM
Axayacatl
Posts: 170 - iTrader: (
did you change the neck? where are the
shark tooth inlays
? and you also changed the bridge?
Axayacatl
Find all posts by Axayacatl
04-19-2008, 05:51 PM
NeglectedField
Posts: 945 - iTrader: (
Ikebe Gakki
do one-off ones that have Sustainer pickups added. And ones with sustainers come with either Dimarzio, EMG or SD pickups. If only ordering from Japan wasn't such a pain.
NeglectedField
Find all posts by NeglectedField
04-20-2008, 08:43 AM
Petie
kool98769
So if theres a section that you want to be a little more warm, you can always switch to the neck pickup.
Or pick with your thumb or fingers. I like having a lot of pickup options but I also like to humble myself every now and then.
Petie
04-20-2008, 02:41 PM
kool98769
Petie
or that.
Depends on how fast the passage is.
kool98769
04-20-2008, 05:07 PM
Of Angels
Posts: 516 - iTrader: (
Petie
Hell yeah - gotta be brutal about it. Gotta take it back to the days of ONLY finger tone/picking dynamics.
Of Angels
Find all posts by Of Angels
04-22-2008, 12:55 PM
albee1952
Actually, intonation checks fine on my peterson and korg rack tuners although I agree that it looks odd. I bought the body by itself as I loved the binding and it is a b*tch to do binding without a CNC machine on any body with a taper like the arm cut on these. I have had single HB guitars in the past(Steinberger and
Kramer Baretta
) and just need more versatility these days. I also only use a pick about 50% of the time.
albee1952
04-15-2011, 11:38 AM
ozzeh
Posts: 100 - iTrader: (
i own this guitar and I absolutely love the single bridge pick up. It makes the player have to rely on technique more so than ever for a WIDE array of sounds. I have an emg 85 installed and by adjusting the volume knob I can get a vast array of 'metal' tones fit for even this most anal tone freaks.
ozzeh
Find all posts by ozzeh
04-15-2011, 12:40 PM
Death.by.G-string
Posts: 336 - iTrader: (
I like the 2610 a lot.
Exept for the pro egde and the SD its great.( prefer the low pro edge)
Perfect for live cause in my book less is better!
i can jump and thrash around without having to worry about hitting a pickup selector and screw up.
+ the less theres on, the less that can go broke.
Death.by.G-string
Find all posts by Death.by.G-string
04-15-2011, 01:35 PM
metalguy
Posts: 324 - iTrader: (
I had one. Buy it. The longer you own it the more you'll love it. It sounds as good as it looks
metalguy
Find all posts by metalguy
bridge pickup
bridge pickups
coil tap
ikebe gakki
kramer baretta
les paul
neck pickup
neck pickups
pull coil
pull coil tap
seymour duncan
shark tooth inlays
Ibanez s320 opinions?
opinions on duncan JB?
Opinions on rg2550e or rg2610e
metalfrk
12:31 PM
Prestige rg2550e or rg2610e
metalfrk
Polls
03:12 PM
Clapton Strat. Need Jemsiters opinions
julio
08:26 AM
Can I get some opinions here? - Need some opinions on AANJ v
trouble311
11:04 AM
02:03 AM
