Please help!
06-06-2006, 03:51 PM
SirGary
Posts: 44 - iTrader: (
Please help!
I realised today that my rg1570 has a TERRIBLE buz. It only happens with the
neck pup
and only when I'm not touching any of the metal parts of the guitar. Also if I turn the tone pot down it stops the buzzing. Could it be something to do with the tone pot's earthing or something? Or is it the pup?
Please help me find out what's wrong! I'm really dissapointed and need to know if there is a real problem with the guitar while I can still send it back. Also, if you know what it is, is there anything I can do about it? The buzz is REALLY bad, and if there is no way around it I might have to send it back
SirGary
Find all posts by SirGary
06-06-2006, 03:54 PM
Eddie_UV777
Posts: 1,179 - iTrader: (
Re: Please help!
I used to get that on my jackson flying V, Im no tech so im not gonna tell you what to do,However I will tell you this. Take it to a tech. no use in sending it back over a buzz
Eddie_UV777
Visit Eddie_UV777's homepage!
Find all posts by Eddie_UV777
06-06-2006, 03:58 PM
jemplayer55
Posts: 2,627 - iTrader: (
Re: Please help!
Sounds like a ground problem..... I agree, take it to a tech. May just be a loose wire or cold solder joint.
jemplayer55
Find all posts by jemplayer55
06-06-2006, 04:02 PM
SirGary
Re: Please help!
How much will it cost to take it to a tech? It's really annoying to spend so much on a guitar and have it have a problem
SirGary
06-06-2006, 04:07 PM
Eddie_UV777
Re: Please help!
not sure. when i had my tech fix it he charged me some nuggets and a soda from wendy's lol. so i cant tell ya,but it shouldnt be that nuch to re-solder
Eddie_UV777
06-06-2006, 04:09 PM
SirGary
Re: Please help!
kk, so theres no way for me to check it myself easily? ARGH, so annoyed, want to stare at someone with my angry face.
Also, is there any chance it could be the cable or something? I didn't notice it yesterday, and nothing has happened to the guitar since
SirGary
06-06-2006, 04:17 PM
GAZ
Posts: 442 - iTrader: (
Re: Please help!
Check your lead(s) and mains socket anyway as a matter of course and make sure the lead is fully in the guitar's
jack socket
, one of mine was really stiff when new. Does it do it on the single coil modes too or just the full
neck humbucker
setting ?
GAZ
Find all posts by GAZ
06-06-2006, 04:19 PM
SirGary
Re: Please help!
just the full neck and (but to a lesser extent) on the neck/middle setting. This makes me think it is something to do with the wiring, as otherwise it would be like it on every setting I would've thought
SirGary
06-06-2006, 04:20 PM
JJEMMER777
Posts: 8,374 - iTrader: (
Re: Please help!
Patience good sir
Jemsite is FULL of very experienced techs/players/vendors that I'm sure will chime in with some advice in due time.
Sounds like the wiring, or even a faulty 5 way. The buzzing could be from a few different problems, but I'm not a tech so I'll let the qualified folks have a go at this
But yeah, as Eddie said, I wouldn't send back the entire guitar for a buzz in the neck pup. Prolly a simple remedy Nice guitar by the way.
Smile
JJEMMER777
Find all posts by JJEMMER777
06-06-2006, 04:25 PM
SirGary
Re: Please help!
...just about managed to do it. It's just typical that I finally get a good guitar, and then theres a problem with it, even if it isnt a major one. Maybe it's the devils work! being 6/6/06 and all!
SirGary
06-06-2006, 04:30 PM
JJEMMER777
Re: Please help!
Lol....
I did have a similar problem in the past and it turned out to be the 5 way. Try moving it back and forth a few times through all 5 notches very quickly and see if that makes a difference. That's how I found out my problem.
JJEMMER777
06-06-2006, 04:31 PM
Eddie_UV777
Re: Please help!
6/6/06!?!? oh man! *hides his jem* I aint taking no chances :P
Eddie_UV777
06-06-2006, 04:32 PM
SirGary
Re: Please help!
If i move the 5 way forewards and backwards, what will I hear that shows me that's the problem?
SirGary
06-06-2006, 04:38 PM
JJEMMER777
Re: Please help!
The buzzing may stop. At least for a bit. Like I said, I'm not a tech, but this was a problem I have encountered and it was the 5 way. Move it back and forth rapidly then back to the neck poisition while plugged in.
If you have to order a new one the part # is YM50. I think Rich has a few in stock at the moment
Otherwise, I'd say it's a wiring issue.
JJEMMER777
06-06-2006, 04:39 PM
SirGary
Re: Please help!
no, no difference. Thanks for the advice though.
SirGary
bridge pup
coil mode
jack socket
neck humbucker
neck pup
07:10 PM
