Problem with a ZR bridge
09-22-2006, 04:44 AM
sandpappy
Posts: 9 - iTrader: (
Quick question for anyone who can answer it(obviosly)
I've just brought a new 2075 prestige with ZR bridge an D tuner the guitar looks an feels awesome but 1 small thing, on the high E i'm gettin a slight buzz it's only the E note too play an F it goes nearly anywhere on the if i play an E hard enough it'll buzz at the saddle anyone else had that problem??? i wanna play around with the bridge setup a bit but this ZR thing's a whole new world from the LO-TRS i've got on the old RG.
Any comments would be appreciated i reallyt don't wanna send it back on warranty if it's something i can fix myself
sandpappy
Find all posts by sandpappy
09-22-2006, 05:47 AM
GTR-MAN
Posts: 1,056 - iTrader: (
Re: Problem with a ZR bridge
I'd like to offer a suggestion but I'm having trouble understanding your problem, "on the high E i'm gettin a slight buzz it's only the E note too play an F it goes nearly anywhere on the if i play an E hard enough it'll buzz at the saddle anyone else had that problem??? " , huh? That makes no sense to me, not trying to give you a hard time but that's absolutely horrible grammer and makes your explaination of your problem unintelligible. If you could try explaining that again so it make sense I'd be happy to offer a suggestion. Either way I'm sorry to hear you're having problems and hope we can help you remedy your issue.
GTR-MAN
Find all posts by GTR-MAN
09-23-2006, 12:12 PM
MetalZone
Posts: 273 - iTrader: (
dude, you need to help others understand what you mean by using proper punctuation.
anyway it looks to be you are having buzzing problems on the low E.
read up on some setups:
http://www.jemsite.com/tech/
MetalZone
Visit MetalZone's homepage!
Find all posts by MetalZone
09-23-2006, 03:43 PM
S-man
Posts: 1,757 - iTrader: (
Like the others, I can't understand what your problem is?
I'd be suprised if it's actually the saddle buzzing.
S-man
Find all posts by S-man
09-24-2006, 04:58 AM
sandpappy
oops sorry guys i'm new to having conversations without having ppl infront of me i can mangle my words a bit.
let me try this again, alright my definition of high E is highest in pitch, when i play open high E or 12th, or pretty much E any where of the
fret board
if i hit hard enough, i get a buzz that sounds like the string's vibrating at the saddle. Why it's only the E is the really confusing bit cause in theory shouldn't it vibrate at the 440Hz no matter what the pitch??
About the only idea i have is that the
bridge angle
is a little too high so the strings is exiting the saddle a fraction before it should but that sounds like a long shot to me.
hope that's better, lookin forward to either being told i suk at explaining myself again or gettin help
Thanks guys
05:05 AM
sandpappy
09-24-2006, 08:19 AM
GTR-MAN
I understand what you're saying now, I have the same problem on my only Jackson and have not been able to figure it out. I wish you luck and hope someone else here may know what your problem is being caused by. My
Ibanez guitars
haven't gave me this issue yet ( I hope they don't ) I'm curious to what will fix your problem almost as bad as you do. Good luck to you !
GTR-MAN
09-24-2006, 12:09 PM
fettouhi
Posts: 9,937 - iTrader: (
sandpappy
let me try this again, alright my definition of high E is highest in pitch, when i play open high E or 12th, or pretty much E any where of the fret board if i hit hard enough, i get a buzz that sounds like the string's vibrating at the saddle. Why it's only the E is the really confusing bit cause in theory shouldn't it vibrate at the 440Hz no matter what the pitch??
About the only idea i have is that the bridge angle is a little too high so the strings is exiting the saddle a fraction before it should but that sounds like a long shot to me.
Thanks guys
Try raising the trem a bit.
Regards
André
fettouhi
Find all posts by fettouhi
09-25-2006, 01:15 PM
Arivergandez
Posts: 19 - iTrader: (
Hmm, I have an S1625 TKS with ZR trem, no probs there tho. But what i did when first got the guitar was raise/lower the action of the bridge. Not familiar witht his problem but if you don't feel comfortable doing it yourself take the guitar back to shop or get it repaired.
Arivergandez
Find all posts by Arivergandez
09-26-2006, 04:31 AM
FMJBT
Posts: 12 - iTrader: (
It might be the
tremolo arm
vibrating in the socket that it plugs into. I've had this happen a few times before I figured out where it was coming from. If not that, just put your finger on random parts of the bridge as you play that E note. When the buzzing stops, your finger will most likely be pointing right at the problem. Good luck,
Mike
FMJBT
Find all posts by FMJBT
bridge angle
fret board
ibanez guitars
tremolo arm
how do u measure a bridge
guitar white hardware bridge
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
problem frequencies when mixing
where to place sympathetic bridge
Problem w/ bridge pickup on my JEM90HAM: as singlecoiled !
nmanel
Pickups & wiring
01:33 AM
Rg-7620 Problem
Sephiroth000
08:19 PM
Putting the new Ibanez ZR Bridge into a 2002 Ibanez rgt42???
ShredBird
04:09 AM
Strats Tremelos, help?
Ignorance
Tech: Setup, Repairs and Mods
04:39 PM
Is this going to be easy??? - Bridge replacement for RG421
ChrisReedSmith
09:25 AM
01:04 PM
