Question on foam
05-13-2006, 07:47 AM
Bezial
Posts: 540 - iTrader: (
Question on foam
hi all , just need to know what sort of foam to use to pack the pickup on my j custom or any direct mount for that matter, i heard that the foam thats under gets to compressed and when you raise them they dont . (hope that makes sense)
is it soft foam squezzy foam or what ? where do i get it and is it as simple as unscrew pickup and then replace foam and set to desired hieght?
thanks for any help
Bezial
Find all posts by Bezial
05-13-2006, 08:20 AM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
Re: Question on foam
Bezial
thanks for any help
That's true about the foam not rebounding, for some reason when I bought a 7321 the neck pick-up was screwed all the way down and the foam didn't rebound and I had to replace it. The foam isn't really spongy, the air pockets are very small, so they look solid. It's the same thin foam Ibanez uses in the trem route's on the face of bodies to protect them from chipping, just a lot thicker. I don't know where to get some, but any fairly firm rectangular foam would get the job done. Yes it's as simple as you think.
brothersnowgone
05-13-2006, 10:48 AM
DV8
Posts: 46 - iTrader: (
You can use the foam that your new pick-ups come packaged with. That's what I did when I changed the bridge on my 1570 to a dimebucker.
DV8
Find all posts by DV8
05-13-2006, 11:08 AM
ibanez2005
Posts: 910 - iTrader: (
Try a bath sponge.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
05-13-2006, 11:09 AM
ibanez2005
Or a car sponge.
ibanez2005
05-13-2006, 11:19 AM
brothersnowgone
Reviews: 7
ibanez2005
Or a car sponge.
That's a bit too soft. If he does any playing while standing and moving around a bit it would probably make the sponge act as a shock aborber underneath the pup. I would opt for something a little more firm, just in case your going to be moving a lot, even if your not it's a better idea to find something more firm.
brothersnowgone
05-13-2006, 12:22 PM
rs70chgrrt
Posts: 61 - iTrader: (
Try a chunk of memory foam. Like tempurpedic mattresses or pillows. I used some for a different application.(To pad an electronic component) and it worked fine. Took it from a neck pillow my wife bought and didn't use.Just a suggestion.
rs70chgrrt
Find all posts by rs70chgrrt
05-13-2006, 02:24 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
try weather stripping. it actually has an adhesive on it. hardware stores stock it.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
05-13-2006, 07:28 PM
Team J Crafter
Posts: 336 - iTrader: (
brothersnowgone
This was the case with my two recent RGT's. The pick-ups were way too low and the stock foam wouldn't rebound. It's and easy fix. I still have the packaging & foam from an EMG set that I used on another guitar.
Team J Crafter
Find all posts by Team J Crafter
05-13-2006, 11:48 PM
Bezial
thanks guys , so a thickish foam is ok as long as it has some give in it.
Bezial
05-13-2006, 11:58 PM
Team J Crafter
You've got it.
Team J Crafter
05-14-2006, 03:18 AM
King Nothing
Posts: 333 - iTrader: (
I havn't looked under my body
mounted pickups
ever but why couldn't u just use springs? Is it too hard to find one the right size that could also hold a pickup and not collapse?
King Nothing
Find all posts by King Nothing
05-14-2006, 01:53 PM
Team J Crafter
King Nothing
I havn't looked under my body mounted pickups ever but why couldn't u just use springs? Is it too hard to find one the right size that could also hold a pickup and not collapse?
In some cases, the pick up doesn't level properly when using springs.
Team J Crafter
mounted pickups
what kind direct mount pickup foam
foam or rubber subs?
QUESTION: what's the next number?? 1, 2, 6, 42, 1806, ? the 6th number is the password to the exce
Jem7PBK - Question about the neck
Martijn
09:04 AM
Quick question on 2x12s
tobe
Gear and Equipment
08:21 PM
Question about ebay auction Question
Miata1476
03:41 PM
Bad horsie 2 question and Amp Question
snorkthesick
Gear and Equipment
05:56 PM
WARNING: Stupid Floyd Question Ahead!
Ugoyin
Tech: Setup, Repairs and Mods
08:56 PM
12:04 AM
