RG 1570 neck shims?
08-13-2003, 08:56 PM
chilln2music
Posts: 264 - iTrader: (
RG 1570 neck shims?
Are there neck shims put in the new RG 1570's at the factory that make the neck angled? I can visually see the neck angled back on my 1570 and was wondering if this could be causeing the difficulties i am having setting up this guitar. thanks!
chilln2music
Find all posts by chilln2music
08-13-2003, 09:00 PM
Posts: 19,348 - iTrader: (
There are no shims, they're buiding it right into the pocket itself. If you pull the neck and measure you'll find a 1mm difference between the back of the pocket and the front.
08-20-2003, 02:09 PM
Paul Secondino
Posts: 401 - iTrader: (
Most of the bolt on guitars tht I own have this angle.It is common to many guitars.IF oyu look at an Epiphone Les Paulo, yo uwill see a more sever angle at the neck pocket.
Paul Secondino
Visit Paul Secondino's homepage!
Find all posts by Paul Secondino
epiphone les paul
les paul
neck angle
neck shim
parker are they neck thru
paf pro vs evo neck?
why is through neck construction expensive to produce?
how do you put the strings closer to the neck on a ZR tremalo
03:27 AM
