Old 12-15-2003, 06:32 AM
WildWayz  is offline
Posts: 279  -  iTrader: (0)
RG 2820 - Pickup combos...
Hi ya all,
I currently have an RG3120 and I am about to buy an RG2820. I wanna get the store to put new pups in her 1st though, soooo what do you suggest?
Air Norton (Neck) + Tone Zone (Bridge)
Air Norton (Neck) + Stevie Special (Bridge)
Air Norton (Neck) + Evolution (Bridge)
My RG3120 has Paf Pro (Neck) + Tone Zone (Bridge) hence wanting something a little different
Thanks
James
Old 12-15-2003, 11:58 AM
dot-dot-dot  is offline
Posts: 304  -  iTrader: (0)
I might be being really dense here, but what are the stock pickups, and what's wrong with them?
Old 12-15-2003, 12:09 PM
WildWayz  is offline
The stock pickups are standard DiMarzio/Ibanez humbuckers - ie low end 'default' pickups.
They tend to not be as responsive as 'full' DiMarzio's (having said that, there is a version of For The Love of God posted on here recorded on a stock RG2820 that sounds ace!).
James
Old 12-15-2003, 01:51 PM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
What wood is the 2820 made out of? (that impacts my recos...)
--B
Old 12-15-2003, 01:55 PM
WildWayz  is offline
Mahogony with quilted (or flamed?) maple top (same as the 3120).
James
Old 12-15-2003, 01:57 PM
BeastofLove  is offline
Posts: 795  -  iTrader: (0)
Personally, I'd go with the AN/TZ combo. The sound absolutely delightful in my RGT3120.
-Ben
Old 12-15-2003, 02:07 PM
WildWayz  is offline
Mmmmm tempting
Hmmm wonder if it's worth coil tapping the pups too... hmmmm
Old 12-15-2003, 10:15 PM
bduersch  is offline
For the Maple/Mahogany combo, I'd recommend either the AN/TZ combo, or if you're looking for a little push over the edge, try a FRED/Super 3 combo. That's what I've got in my 3120 now.
--B
Old 12-15-2003, 11:17 PM
kp69  is offline
Posts: 82  -  iTrader: (0)
I'm not a big fan of the tone zone in the 3120, but that's not me. I ganked mine recently. You might like it but personally I'd go with something else.
Old 12-15-2003, 11:27 PM
The Madness Here  is offline
Posts: 249  -  iTrader: (0)
i personally like the TZ in mahogony,
but youve already got a 3120 with a tz in the bridge so id suggest going with something different thats why you;re getting a new guitar right? for something new.
Id suggest going for something entirely different, like an Air classic in the neck and a Bluesbucker in the bridge.
or try going for Duncans.
Try going for a sound that will make this guitar entirely different from your 3120
Old 12-16-2003, 04:38 AM
James
Ah - makes sense. The 2820 isn't in my catalogue, and I'd guessed (incorrectly!) that it'd have "real" DiMarzios.
Old 12-17-2003, 02:35 AM
triaxis  is offline
Posts: 118  -  iTrader: (0)
Hmm..I have the RG2820..and I installed dimarzio Air Norton and Steve Special in them. I've recently posted some clips I did, directly recorded into my PC using the V-amp 2. I really like the Steve Special, esp when I use it with my Dual Recto
Here are some clips, might give you some idea how they will sound:
http://www.digitalsoundplanet.com/Vi...hp?eltid=13421
http://www.digitalsoundplanet.com/Vi...hp?eltid=13419
http://www.digitalsoundplanet.com/Vi...hp?eltid=13136
Old 12-17-2003, 02:39 AM
WildWayz  is offline
Thanks Triaxis I heard your Erotomania clips before - very nice
Did you have problems installing the pickups? I heard a few people did...
James
Old 12-17-2003, 09:08 PM
triaxis  is offline
James
Oopss hehe thanks for the comments!
Before I installed the pickups, I carefully removed the original foams on the stock pickups. The weird thing is I needed to put in the foam only on the neck pickup (air norton) but I didnt need to put a foam on the bridge pickup. The height in the neck was a bit too low if I didnt slot in the foam pieces but it was just right for the bridge pickup. Not sure why this is so or maybe its a personal preference when it comes to pickup height I guess. I prefer my neck pickup to be slightly closer to the strings and also because the AN is not a very hot pickup so I needed that little bit more output
Old 12-18-2003, 02:33 AM
WildWayz  is offline
Hmmm what do u mean about "foam"?
Been a couple of years since i played with pickups, but cant remember seeing any foam on the paf pro/fred that i touched.
My RG2820 was meant to be delivered yesterday - courier didnt even ring the door bell - just put a card through saying we weren't in (which we all were home!) They will try delivering today.
James
air norton, bridge pickup, coil tap, coil tapping, dimarzio air, dimarzio air norton, dual recto, neck pickup, paf pro, pickup height, tone zone
