Rg 3120 Problems. ANNOYING PROBLEMS!!!!
04-26-2003, 12:18 AM
Given to Fly
Posts: 450 - iTrader: (
Basically, everytime I change the strings on my RG 3120 the bridge gets screwed up. Like it is pulling back too much or not enough or it never stay in tune, take your pick it's happened. Now I use the exact same strings and I just had it set-up by a technician so things should have been fine. But I put new strings on and the bridge its pulling back too much. I don't think I'm doing anything wrong, but should the guitar do this? My faith in Floyds is leaving me quick. Please help!
PS I'm using Thomastik Power - Brights .009 - .042
Given to Fly
Find all posts by Given to Fly
04-26-2003, 08:00 AM
Iddlypods
Posts: 12 - iTrader: (
Are you stretching the strings before putting them on?
Iddlypods
Find all posts by Iddlypods
04-26-2003, 01:29 PM
Jeff
Posts: 1,501 - iTrader: (
How do you stretch them before you put them on? Usually you put them on, then stretch them.
Jeff
Visit Jeff's homepage!
Find all posts by Jeff
04-26-2003, 02:21 PM
SinTrade
Posts: 56 - iTrader: (
JEMavenger
take two fingers and "lift" the string from the neck...got it ?
SinTrade
Find all posts by SinTrade
04-26-2003, 02:39 PM
pawel
Posts: 2,656 - iTrader: (
SinTrade
JEMavenger
He meant that as a joke
pawel
Find all posts by pawel
04-26-2003, 03:01 PM
SinTrade
pawel
ups...guess its time for bed
SinTrade
04-26-2003, 06:01 PM
Axefretters
Posts: 20 - iTrader: (
Find a new tech. I have had to correct many problems similar to yours from friends who use bad techs. Best advice is to find someone who can correctly teach you or just learn through trial and error. It will save you time, money, and hassle to do it yourself. There are several sites around that will give you more than enough instruction. Good luck
Axefretters
Find all posts by Axefretters
04-26-2003, 06:42 PM
caprile
Posts: 1,619 - iTrader: (
Follow Rich's setup guide step by step-
btw.....you change strings one at a time, right?
caprile
Find all posts by caprile
04-28-2003, 09:29 PM
agquake
Posts: 171 - iTrader: (
Yes....do you change strings one at a time?
agquake
Visit agquake's homepage!
Find all posts by agquake
05-01-2003, 01:46 AM
Petie
Posts: 2,877 - iTrader: (
Oh god I wish the internet was around when I got my first Edge-equipped axe. Nobody ever told me not to take all the strings off at once, or that if I tried to tune down to C# for Sabbath Bloody Sabbath I'd actually end up at about F#! I had to learn all that stuff through trial and error because nobody knew how to handle a guitar like that where I lived.
Petie
Visit Petie's homepage!
Find all posts by Petie
05-01-2003, 10:59 PM
little wing
Posts: 368 - iTrader: (
Same goes to me Petie... Nobaody told me above Flyod Rose's and i ended up taking of all the strings everytime i change them, using different gauges everytime, and ended up in trouble everytime!
little wing
Visit little wing's homepage!
Find all posts by little wing
05-01-2003, 11:26 PM
caprile
happily, my case was the opposite.....I memorized everything I found here for years before getting an Edge...sweet from day one
caprile
05-02-2003, 01:35 AM
steve
Posts: 590 - iTrader: (
I may be the only person around here who takes strings all off, every time, whithout hassles. There's no other way to /completely/ clean an instrument up, in my opinion.
We all have our different ways; I suppose it is safer to warn those less technically inclined away from removing them all at once (as you should remove the spring tension and such to balance it out - or use a wedge, which I do not, etc), but I think anyone who is going to look after all day-to-day aspects of their instruments should ultimately be comfortable with re-stringing a floating bridge guitar right from the point where the bridge is on the table next to the 'naked' guitar. Like anything else, there are bad/good/better ways of doing this, as well...
steve
Visit steve's homepage!
Find all posts by steve
05-02-2003, 01:54 AM
Posts: 19,352 - iTrader: (
I never change them 1 at a time. 95% of the guitars I prep the neck is coming off anyway. Even my personal guitars [when I used to keep a few around to play] I'd pull them all. The board woiuld usually be *really* cruddy [as well as the strings], I always hated changing strings, now I do it everyday [and still hate it!].
05-02-2003, 02:38 AM
agquake
Rich, can I assume you put a wedge under the bridge when you pull all the strings at once?
agquake
ibanez trem
string gauges
trem guitar
Problems with bare wood neck guitars
firepod problems after firmware update
ibanez 3120 with ebony fingerboar?
tremolo problems and how to fix them
are there any problems with metal pickguards?
05:51 AM
