Old 04-16-2006, 08:44 PM
ANT  is offline
Posts: 1  -  iTrader: (0)
RG Prestige 1620X buzzing problem
Hi, I recently bought an RG Prestige 1620X (new, not used), equipped with double edge tremolo with piezo output. I have the following problem: when I play an open G String, there is a hardware part on the guitar (I guess) that buzzes. I have checked the neck and there is no fret problem. Any idea to stop this noise?? Thank you in advance.
Old 04-17-2006, 04:26 AM
Shredder87  is offline
Posts: 417  -  iTrader: (0)
Re: RG Prestige 1620X buzzing problem
Is it a sort of resonance coming from within the body? It could just be the springs etc. in your vibrato resonating. I occasionally get something similar.
Can you hear it through your amp? If not then don't worry about it. If you can, try packing the vibrato cavity with tissue or something to stop the resonance.
Also check your locking nut is tightened, check the tuners, vibrato arm and all other components on your guitar. It could be something as simple as a loose screw.
Hope this helps you. Good luck!
double edge trem, edge trem, locking nut
RG tone pot problem Shredder87 J-Custom, USA Custom & Prestige Ibanez Guitars 3 04-16-2006 07:02 AM
RG 2620 Prestige - sensible and cool mods? Marko@Rockvoice J-Custom, USA Custom & Prestige Ibanez Guitars 1 02-14-2006 10:17 PM
Ibanez RG 2680 Prestige - Anyone see one of these??? Seahawk29 J-Custom, USA Custom & Prestige Ibanez Guitars 2 02-13-2002 02:37 AM
New RG Prestige models - RG2680, etc. YJM Other 6-string Guitars (non-Ibanez brand) 5 11-28-2001 11:09 PM
Anyone have a 1992 catalog? - RG 1200 Prestige ??? Jack Butler J-Custom, USA Custom & Prestige Ibanez Guitars 4 09-02-2001 02:34 AM
